PMB Racing Setup Station & Board!
Guys,
Is anyone using the PMB Racing setup station for the 1/10th scale or there setup board? What are your thoughts and how does is compare to Hudy and Intergy/Eagle?
Re: PMB Racing Setup Station & Board!
Originally posted by S710_Nut
Guys,
Guys,
i had the pmb before my hudy. they are both the same. just as acurate except the pmb is made out of thinner perspex. i found that the extching towards the higher numbers (ie10degs etc) was a bit "smudged" ie the etching acid look like small runs through the masking. but it did not effect the accuracy.
i think it will provide the same results with hudy, like in any type of ruler where measurements will always be the same. the only thing i don't like is its hard to read since the marking is color white,....a bright lamp will help.
