Clutch Help ?
Clutch Help ?
Well I took my car out for the first time today and had a minor glitch I set
the clutch up pretty much as the manual described with the exception of
shimming the clutch bell out so it did not drag on the shoe.
The clutch spring nut was at about .8 and the end play on the bell was at about .4.
When I ran the car it took alot of rpm for the clutch to engage and
when you would run at part throttle it seemed as though the clutch would
engage/disengage almost sounding as if the engine was surging but I am sure
it was the clutch.
Is the clutch spring to tight for having it shimmed away from the shoe.
I am sure I am not the first to have this happen so rather then play around I thought I would ask for some help.
Mugen MRX4X
it was the clutch.
Mugen MRX4X
No it seemed to happen no matter what the engine temp.
If I gassed it hard it would blast away but at part throttle the cluch seemed to go in and out so I wodered if it was a symptom of clutch spring adjustment.
One thing I did not mention was that 2 of the four flyweights of the clutch are stock the other 2 have been drilled to 4mm.
It was that way when I got it is it possible the clutch flyweight are too light for the .8 spring nut adjustment
Clutch
Thanks for replying it was getting late so I decided to call it a nite after I lost the only E-clip I had for the two speed tranny, spang off in the parking lot I did not have any there with me. (dupdi doo)
I did not even think about the flyweights untill after the first post.
The set of flyweights I have in the car are the only ones I have I quess I could fill one hole with epoxy for testing. I am planning to order a set after I figure what else I need to order.
Thanks again.
Thanks again.
Clutches are sooo important and if you ask 5 people you will get 5 different answers. Then you'll get the answers like this is what the pros do to their clutch but keep in mind not everyone can get the benifit out of it or even control the car with a clutch like the pros. I think you should just use the stock settings and use the spring to adjust after you have the proper gap and end play. Hope this helps. Any ? Pm me.
it was the clutch.
Mugen MRX4X
it was the clutch.
Mugen MRX4X
cheers
Centax 2 and 3 building and setup.doc
Also,,
Try to listen to it closer,,It may be the 2 Speed shoe shifting & " Down shifting " Double clutching as some would say. Just throwing that out there.
Cause Normaly .8 and .4 with a fresh pad is a good starting point.
Clutch
Thanks for all the input after reading these clutch setup sheets I definitely did not have it set right.
I will try it again with the proper setup and let you now how it went.
Are there 1/8 guys in Tampa every weekend I want to go over there next weekend before I try it at Kissimmee.
Thanks Again.
Thanks Again.
Most of Your 1/8 scale Gatherings will be during the ( ALL STAR RACES ) in tampa. So next weekend is probably gonna be no good for 1/8 scale. Check SS Speedways thread in the FL. section for the next all star dates. And Talk Greg Into driving over
