Old 02-07-2009, 09:30 AM   #1
taytoncot's Avatar
Default tire tuner
hi all can someone tell how to use the tire tuner for 1/10yh and 1/8th on road.
i have tried but not sure that i am doing it right
taytoncot is offline   Reply With Quote
Old 02-07-2009, 10:00 AM   #2
wizby's Avatar
Do you mean a tire truer? What do you actually want to know? Are you asking what size to cut too?
wizby is offline   Reply With Quote
Old 02-07-2009, 10:05 AM   #3
Team Speedy's Avatar
Trader Rating: 41 (100%+)
What would you like to know about it?
On my Ofna Automatic I bolt the tire to the arbor, use the tire depth adjuster to cut what I want off it. Press the on switch to spin the arbor, press my direction button (or hand crank depending on your model) and off I go. My first pass is my rough cut to make sure its the correct size, my second back pass touches it up and my third and fourth pass (second cycle) are my final cuts. Once I get the proper depth I want I'll true a few more tires and call it a day. You may want to consider having a caplier laying around just to be sure your not cutting those tires to the wrong size therefore costing yourself a new set of tires if there too low.
Its important not to touch your depth adjustor once you lock in your desired mm/inch cut. Reason being is that you do not want one tire at say 56mm and another at 57mm (unless your doing this for say tire wear rates)
After I'm done truing my tires I take a file and round off the edges of the tires a bit.
Here's a video I found on youtube, this is merely for reference.
I hope that helps you abit! Best of luck with it.
RcAmerica | Xray | Hudy | Motiv | Orca | Sanwa |
Team Speedy is offline   Reply With Quote
Old 02-07-2009, 04:16 PM   #4
freestyles's Avatar
Trader Rating: 14 (100%+)
Just make sure you don't do it to fast or too much at a time or it will chunk your tyres
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
T.R.C.R. ---Pit's Talk--- teambighead Northwest Racers 25117 10-22-2016 08:39 PM
1/10 RC RALLY Blueshark Singapore R/C Racers 775 03-12-2016 03:17 AM
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 12:18 PM
Drifting mr4tcsdrifter Colorado Racing 2678 11-01-2011 09:34 PM
STOCK motor forum porkybmx Electric On-Road 2817 12-11-2007 01:20 PM
SEO by vBSEO 3.5.0
