Old 11-06-2003, 07:51 PM   #1
Default M8 Radio trouble
I could use some help.
I have an M8 that I have been using for about 3 months and just recently I have been getting little radio hits. They only occur when the car and radio are about 200 feet apart. When I bought the radio it came with 69 crystals. I changed to 73 to avoid local club conflicts. Where do I go from here. Has anyone had experience with bad crystals. I have not tried to switch back to 69 yet. Sort of hesitent to do anything without some advice.
Regards Marty
martymarine is offline   Reply With Quote
Old 11-06-2003, 07:59 PM   #2
InitialD's Avatar
I guess the only way of making sure is to test out the 73 crystal ! The problem could be anything. I guess you need to do it when nobody is on the track to avoid glitching.
I once spotted a problem I was having due to a bad receiver pack. Another time was due to a loose antenna connection that gave the same symptoms you had described. Hope that helps.
Old 11-07-2003, 05:57 PM   #3
Flash Gordan's Avatar
Send a message via AIM to Flash Gordan Send a message via Yahoo to Flash Gordan
Definitely check out your reciever. Had some of the same problems earlier this year until I replaced the reciever. Haven't had any problems since.
Flash Gordan is offline   Reply With Quote
Old 11-07-2003, 06:08 PM   #4
Nitro Tech
dino.tw's Avatar
Cut a bit fuel line to put on the crystal.see the attachment.It may work!
dino.tw is offline   Reply With Quote
Old 11-09-2003, 01:28 AM   #5
theRED5's Avatar
R/C Tech Charter Subscriber
If the Rx has been run in an onroad car before you got it? I suggest opening the RX case up and blow it out with tuner cleaner, you can get it at Radio Shack.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 11-12-2003, 05:40 PM   #6
I thank you all for your insight and tips. Turned out to be interferance from my transponder. Shielded reciver with foil tape. No more hits. Thanks again all.
Regards Marty
having trouble pagmazdan Electric On-Road 2 05-10-2007 07:44 AM
trouble with my tc3 okczy21 Nitro On-Road 5 08-05-2004 07:46 AM
HELP PLEASE trouble with a 4 tec emaxxracer Nitro On-Road 2 03-09-2004 12:46 AM
Having Trouble!!!!! church Buyer/Seller dispute and Feedback discussion forum 6 12-12-2003 11:12 AM
SEO by vBSEO 3.5.0
