K Factory NTC3 Steering / Hub Carriers
When are these going to be availalble?
We will ship them to the US next week.
NTC3 Racer
I see that these are just like the GPM parts, but not aluminum. What is the advantage to this part over the aluminum one? I have been running the GPM part because I have had no other choise, but with this part, does it give a better setup option? courious...
1. Different pillow ball nut system--It is easier for you to adjust the play.
2. For the rear, you have 4mm adjustable rod & stronger nylon parts. The toe angle will be the same after the crash. 3. The rear toe linkage (hub carrier side) has ball end design, instead of the screw-nut design. This makes the movement pefect. 4. Special nylong material, lighter. |
They look great to bad I wont have a set by this weekend for the Regionals.
I would like to try a set, but my last race this year is next weekend. A 500 lap Oval race in Montgomery, AL. I don't think they will be here by then.
Hi Nick..
Does trinity know these parts are coming?... And is there a part # we can use to shop for them?... Thanks harry |
oh well!
will there go's a possible good thing.:flaming:
K1249 NTC3 Special Nylon Steering Blocks
K1250 NTC3 Special Nylon Rear Hub Carriers (w/4mm adjustable rods) We already ask Trinity to order. |
Nick,
I see you say the are lighter than stock, are they stronger? Tom |
Do they use the same size bearings for the axles?
A larger bearing would be a real plus. |
They are much lighter than the alum., not sure about the stock. May be similar.
The original bearings fit perfectly. |
TMnick
I agree with snemi00, larger bearings would be a plus, will this be an option in the future??
thanks jason |
We will check & do our best.
