Old 02-02-2009, 12:49 AM   #31
dnitro's Avatar
Hey Andy,
IMO, just keep the stock gearing because the OS 18tz has plenty of power for super quick acceleration. The ED transmission is also desiged for a 1.8 - 2.0mm split between the front and rear foam tires. Without a split, the ED will be harsh on the belts. If you are bashing, just use soft rubber tires, and softer springs in the rear. Also consider using a diff or spool in the front instead of the stock one-way so you can have 4 wheel braking.
good luck
IDM Evo3
dnitro is offline   Reply With Quote
Old 02-02-2009, 01:26 AM   #32
Thanks for the info. Ive been told by a lot of people that i should be gearing it up before i drop the engine in, because its so powerful
Engine should be here in a few days Will keep you posted.
.:Andy:. is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11757 10-11-2016 09:24 PM
Team Magic G4RS 2009 gtrmx Nitro On-Road 1712 03-31-2014 06:39 PM
HPI R40 Nitro Car Forum EVOLUTION Nitro On-Road 11979 06-26-2012 07:57 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 06:15 PM
Supporting your LHS va_connoisseur Nitro On-Road 51 06-18-2007 01:12 PM
Trinity G4 - Team Magic G4 E-Type puma1824 Nitro On-Road 3128 10-04-2005 04:17 AM
SEO by vBSEO 3.5.0
