Serpent 710
Originally posted by n1technik
hey guys, any idea on why my kit came with black flywheel and hudy spring steel colored pinion?
and it didn't come with a spacer for the pinions.
i do remember the flywheel being "serpent flywheel color" when i built 710 last year. anyways any info would be appreciated.
Originally posted by KevinS
Looks like you have a kit from a new batch. The brown pinion replaces the black pinion for which you needed the spacer. Never seen that black flywheel though...
Got a thicker rear shocktower, thicker bumber plate and longer rear lower arms too?
What's the purpose of the longer rear arms? For more rear camber?
Originally posted by Sow&Steady
Oh, the new kits come with thicker rear shocktower, thicker bumber plate and longer rear lower arms?
Well, I just got my new 710 to store beside my other one and it didn't come with any of the upgraded parts except the black flywheel and spring-steel-coloured gear.
Personally it makes very little difference to me - I've not broken anything since getting my first 710 even though I was practicing running into concerete curbstones on my track at the weekend
The 710 ran brilliantly both on Sat and Sunday here - my only change to the standard setup was to mount the front shocks on the lowest setting, remove the front anti-rollbar and set the right rear camber to -3.5 degrees.
I was getting minimal understeer going into the high speed turns (and was quicker than all other 1:10ths through there) and none at all into the hairpins.
Coming out of the turns the car drifted nicely and gave the confidence to really nail the throttle early and get good speed on the straight.
Under breaking, the rear end would lose just enough grip to give a really nice turn in.
It was really breath-taking to drive the car now just got to wait a couple of weeks until my next bike race is over and then I'll be back at the track!
Cheers, Mark.
The longer rear lower arms (A-arm + DRS arm) are to prevent the pivotballs from being ripped out on impact.
OH MY GOODNESS!!!!!
It's a sweet system. Can't wait to get a hold of one.
Re: OH MY GOODNESS!!!!!
Originally posted by markp27
Check out this all in one setup system from Hudy!
http://www.hudy.net/
It looks amazing!!!!!!!
Yeah, that thing does look nice.
I first noticed it here http://www.rcamerica.com
It's in a small picture on the bottom left.
They know I can't refuse to buy it... they just know!
Originally posted by brian6989
Can someone please help im new to the 710 (switched fromNTC3)and the stock set-up with (37 foams) didnt seem to work very well on my track(very loose) . Can someone thats tryed a set-up off mytsn.com give me a good one to start with. The tracks we usually run on are medium traction, medium size, fairly open. I have a Hudy set-up system. Thanks for the info
Sorry but you coming from the NTC3, the first thing that comes into my mind is your rear diffs are slipping.
Originally posted by Top Gun 777
It is overeving when he hit the triger, right he release it to drop speed little bit. It happned only on the exit from straight , doesn't happened nowhere else.
Re: Re: OH MY GOODNESS!!!!!
Originally posted by packetdreamer
hudy just missed out - just got my integy system a few days ago... ho hum.
