Serpent 710
Re: Re: Re: Re: Re: Re: LRP race
Originally posted by markp27
We need someone to pursuade D to go - and seeing as you own big aeroplanes, maybe you can give him a lift there
Re: Re: Re: Re: Re: Re: Re: LRP race
Originally posted by Julius
At the moment I'm not planning to go. That is the time I normally go skiing. And my holidays are limited. I try and have a social life next to racing these days
Anyway, congrats to you, Michael and the rest of Team Serpent for a fine run.
Originally posted by lagnaf
Here is another one in the boxes
BTW, nice ride lagnaf.
Originally posted by Canuck
Gosh, I just blew my rear diff. Melted the plastic around the balls in the 45T diff gear...
You can try the HK online shopping sites (www.rc-mushroom.com) or try The Border (http://shop.the-border.nl) or RCCarinternational (http://www.rccarinternational.com)which both are based in Holland.
Originally posted by Fernando_M
What about spring pre-load?
Originally posted by Proficar403
I tried the yellow shoe this past weekend. Are you still running the yellow clutch shoe with a .7mm gap?
Suspended
NEW 710 RIMS
WHEN ARE THESE COMING OUT?
Originally posted by InitialD
I'm currently using 0.7 mm clutch gap, yellow shoe, cut flyweights to mount it in the center of the flywheel post and with 2 M3x4 set screws on each flyweight like what Pyramid / Golfinger did. Boy, a lot of punch ! Julius was right to say that it bogs the engine down a lot. I had to use the super hard Mugen spring and crank the spring all the way down to like 1.2 or 1.4 mm from the clutch nut threading (did not really measure) and it started to engage right.
It still did not feel perfect, but I just went with it...I had other problems to deal with. At that point, I would have taken the black shoe setup I had previously over the yellow shoe setup, but I did not have the time or motivation to rebuild and reset my clutch.
I think that I will move the gap to .7 and tighten the adjustment nut a little more before I go to the track again. Hopefully this will give the results I want.
For anyone that is interested, my SARCAR race report --- 710's took 1st and 3rd. Link, with photos, is:
http://www.rctech.net/forum/showthre...917#post959917
Re: Re: LRP - nitro Tourin car masters
Has Alain Levy gone to Mugen
So Mr. Levy now tired building the diff? (j/k)
I did not have too much time to experiment, but I started with a .5 gap, yellow shoe, and stock flyweights with one set screw in each ("glenn cauley" style). Like this, the clutch bogged the engine horribly. I tightened the adjustment nut a few times...which didn't work well enough. I then increased the gap to .6.
Re: Re: Re: LRP - nitro Tourin car masters
Using black stock shoes with the flyweights cut and installed in the middle of the fywheel post and with 2 M3x4 set screws on each shoe, I had to really crank down the pre tension clutch nut to 1.5 mm thereabouts. This is with the stock softer Centax spring.
I forgot to add that I had the bogging problems when I changed to the yellow shoes. Not that it is bad but that goes to show that the shoe provides a lot of grip.
I don't really feel that I am too far away from where I want the clutch set. I doubt that I will need to change to a harder spring for my home track, but it is probably something I will end up playing with soon. Right now, the only spare spring I have is a mugen silver spring...I believe it is the hardest one mugen makes.
