Serpent 710
MAX pipe
who has tried the new max pipe with the short mainfold ?
Pipe? how it helps
How does pipe influence the performance?
I really want to know
Re: Pipe? how it helps
Re: MAX pipe
i agree that the shark pipe is very good in bottom but did you encounter the pipe was very high fuel consumption ? I used shark but end up it could only last 5 minutes, that is my concern. i am not only the one who have had this issue.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Winternats 2004
Originally posted by Sow&Steady
No problem ... I supply fuel and starting equipment ... deal?
Originally posted by InitialD
What plug are you using? Hotter plugs consume a lot of fuel. That's what I found. I remember on my Max, I added 0.1 mm shim to the head (total 0.4 mm). I used to get about 6 to 7 minutes per tank with the carb insert taken out on 25% nitro and with no. 6 plug.
Bit contrary for me but must try one day.
With Max engine in big track, most of us is very difficult to make 5min+1lap with outlaw pipe, especially the"P" series.
The S series is a "bit" better.
I believe yours is "team" batch
Originally posted by GoldFinger
Something new for me bro.. why you taken out the card restrictor while reducing compression?
I actually had a bad run last weekend. Engine kept flaming out on the same spot out of a hairpin. I thought it was the clutch rubbing the shoes. Reshimed and changed the clutchbell. Same problem occured. Went back and found out the fuel tubing near the carb got severed ! I think that was causing the problem.
New to Nitro
Hi Guys,
Just need your opinion. I have an unbuilt Serpent 710 and a Helios arriving next week. I don't have the budget to getting digital servos at the moment, but do have spare Futaba S3004 servos. My question is, will the servo work properly with my Helios. Some say that it will burn it because of the HSR thing. Is it true and can this function be turned off?
Looking forward to your reply.
Regards,
Titan
Regards,
Titan
I think that's because you like to play with the middle brass needle with your throttling style... The leaner MSN setting, the fuel consumption goes higher.
So this is your new trick to get 6-7 minutes?
Re: New to Nitro
Originally posted by Titan
Hi Guys,
Regards,
Titan
Hi Guys,
Regards,
Titan
Hmmm...I think you can use any servos but you'll have to switch something on the back of the Helios back to NORMAL mode...the other 2 settings are for HSR Mode. Gotta check.
Browse here for more FAQ on Helios.
Originally posted by Pyramid
S9451 will fit just find. If S9550, you could mount it from bottom of upperdeck which will give you lower CG...
Re: Re: New to Nitro
Originally posted by cyba888
I checked out the S9550 and its not as long but there must be a downside to it. It seems like it doesnt have as much torque and speed? I think the S9451 suits my 710 better
