Serpent 710
Originally posted by markp27
Sow, that was a Mugen modified version - I didn't like to put my name on it as I simply discovered the modification, I didn't implement it
Re: Re: Re: Big shiny hot thing in the sky!!!
Originally posted by GlennCauley
And Calgary LOST
And Calgary LOST
Originally posted by FW05R
do any of you guys have a Rody Roem RB Engine how does it compare to the other moded engines like JP, MF max in terms of bottom end top speed
From my no-so-stellar tuning skills, I think the JP was a better in the whole range of powerband. The Rody is only slightly lacking in the top end but I found the answer to that ... the Outlaw Shark pipe (not the in-line version).
Also, the JP really takes off as it gets hotter (125C) but the Rody does not like to go above 110C.
I was at the track tonight again and I couldn't believe how well the car took off when I hit the throttle. I've leaned down the LSN now, so the pick up is a lot better - just a little bit more work on the HSN and I'll be hitting the 115C runs
Im hesitant on purchasing a JP FX because most people say they dont last long due to them being race bred engines basically you would only slap the JP on your car for a big race and then take it off and put a less expensive engine to practice with. Im looking for an engine with good power both bottom end and top end that will last me a while
im willing to spend in the price range between $300-$400 for a good engine
Shock tool
Originally posted by InitialD
Somehow, that question of mine was like a trap. Sorry to make it sound like that but I was quite sure that you held the shock shaft the way you did... With the sharp wire cutter portion on the end of the needle thread.
Do away with that method. I've tried that and it simple makes a notch at the end of the thread and gives reason for the shaft to be weak at that spot.
Like what modellor (oophs Palmaris Europe ) does, I use a paper towel and grip the shock shaft with normal pliers. Works for me. And you will not break shock shafts.
Originally posted by rwisejr
I just bought one of these http://www.lcollari-innotech.com/english/12/due10.htm I paid 230.00 for this monster and I 'm about to go run it in on the RIB.
If that is correct, Novarossi must be doing something wrong!
Far from wrong. They couldnt give Collari .12 engines away free here they were so poor . Standard 3-port RB X12 (non-turbo) was blowing them away.
More like 1.4hp of unusable power
Originally posted by Pyramid
Correct me if I`m wrong, JP is the only one who cares about hardening its engine material (Black Case, etc) that logically will be more durable. They will last longer..
But I do agree that coatings on the crankshaft and crank pin is definitely a plus. KHM does that also I believe.
I know that on the older Collari engine (Picco based), changing the carb to a Nova one made a hell a lot of difference. When tuned properly, it will beat even the best engines on the track. Don't know about the newer Rossi based designs though or if you could fit the Nova carb on it.
Are you referring to the older Collari engine based on the Picco engine or the newer one based on the Rossi design?
