Serpent 710
Re: Re: Re: Removing oil from tyres
Originally posted by markp27
Well, got it upto 100C and this thing absolutely screams - it's more like the 1/8th 3.5 Motors in terms of sound
didn't know that - thanks for the tip
Big shiny hot thing in the sky!!!
Not sure how many of you guys will get to see this, so here's a pic of the crossing of the sun by venus!
Not the best picture I've ever taken, but I was avoiding being blined whilst using my big lens
Re: Re: Re: Some testings...
Originally posted by InitialD
Once you drilled the extra 2.5 mm hole (the other hole is the existing one), you could always take out the two M3x4 set screws if you do not like it.
Glad to see the 3hobby site survived the pea brain invaders!
Re: Re: Re: Re: Some testings...
Originally posted by Sow&Steady
Right ... another "reversible" mod.
Re: Re: Re: Another tuning question for Master D
The pinch test does confirm what you say, but the only thing which I was concerned about again, is that the gap on the throttle barrel in the carb is again less than 1mm - are you guys certain that your gaps are 1mm? I measured mine and its about 0.7mm. Leaning the LSN and the adjusting the idle screw will lower this again.
Cheers, Mark-
Cheers, Mark-
All the needles are inter-related so as a guideline, what I see most engine "gurus" write/say is that with a gap of 1mm or thereabouts and with all 3 needles (LSN, MSN, HSN) set correctly, your engine should purr, growl and ROAR ... respectively!
It took me looong time to come to grips with engine tuning (and still learning a lot) but what I did experience in the past is that if you have your idle screw is set too small (less than 5mm), you *can* get a purring idle and you may even get the engine to go fast with this despite what looks like a non-optimal setting (you know how we're all good with tuning screwdrivers and various fuel brewing!) but you can bet your bottom dollar that all it takes now is the slightest change in ambient temperature or humidity and you'll be scraching your head again because the poor engine will get "cranky". If you race enough, you'll see some friends who kicks bu*t during free-practise and then have problems during the mains.
Re: Re: Re: Re: Re: Another tuning question for Master D
There is.
There is.
Re: Re: Re: Re: Re: Re: Re: Another tuning question for Master D
Certainly will but it may take a while as I travel to the alps tomorrow oh man, why didn't I take two weeks holiday and spend them at the track
do any of you guys have a Rody Roem RB Engine how does it compare to the other moded engines like JP, MF max in terms of bottom end top speed
Re: Big shiny hot thing in the sky!!!
The 2106 should be standard NovaMega. KHM version would be hand modified. MS version (like JP versions of the NSR) would be factory modified.
And the MP version has a modified conrod!
Re: Re: Big shiny hot thing in the sky!!!
I wanted to see it on telly last night but ended up watching game 7 of the Stanley Cup finals instead
And Calgary LOST
FW05R do any of you guys have a Rody Roem RB Engine how does it compare to the other moded engines like JP, MF max in terms of bottom end top speed
