Serpent 710
NSR12S3=TSR12S3=RER12S3
Originally posted by BIBOY
check this out there are two of the rex version and the novarossi version RER12s3 or the RR12L both are avalable in 5 and 3 ports
http://www.novarossi.com/default.htm
I just seen it on that link you gave.
The RR12L is a long stroke, isn't it?
Originally posted by PSI Racing
Wouldn't the Novarossi version be the NSR12S3 and Not the RR12L?
Two very good motors !!!
I'm off to a race now...wish me luck guys.
I wanted to run the RR12L5 badly but just couldn't get it run-in in time for this race...
hey guys found an new 2103 ms nova mega; i'm thinking about buying it and use as a back up when more 2106 are available. What u guys think. by the way it is priced at 140
Re:Re: SWITCH
Originally posted by buboy28
GUYS, ARE YOU STILL USING AN ON AND OFF SWITCH OR DO YOU CONNECT THE RECEIVER DIRECTLY TO THE RECEIVER BATTS TNX........................
Originally posted by InitialD
Cool. I assume the crank timing window on the crankshaft is different too?
The difference is that the ports in the cranckshaft are shaped more deeper(in novamax) than the original Novarossi.....so there is more volume outside the sleeve....
It is useful
Short Wheel Base Mod for 710
Do you feel your 710 needs even more than the ample steering it already has? Do you also want more agility because you are racing regularly on tight and technical tracks with a few quick changes in directions required?
Head over to 3Hobby.Com and read the article "710 Rebuild: Mods First". Among others, the article shows you a mod to shorten your wheelbase just for the above purposes.
Originally posted by GoldFinger
Dont forget to borrow a heat gun/hair dryer before 1st start up.
It makes a lot difference in rod life.
Watch the different "sound" it will produce.
Yesterday is my 1st day I crank my KHM 21 on the bench.
I shut it down on the second tanks, the engine is producing a scarry pitched sound in the mid to top rpm.
I thought that I had a bad batch of KHM but after talking w/ my partner who ride it already, he assure me that this engine is really having different "sound".
So i supposed it was came from the ceramic pitching.
I must wait till this sunday to install the ceramic to my RR to proove it and hopefully can answer bro D question.
Do any of you guys have a problem with the front pillowballs pulling out of the hub carrier? Also, has any company made front swingshafts/cvds that are any good?
Originally posted by Palmaris Europe
Dont worry. All KHM's sound different. Just ask Sow&Steady what Mark Green's little KHM Mega .12 sounds like compared to the rest . The .21's are just the same.
