Serpent 710
Originally posted by SupermaxxRich
They do make spring steel one I believe?? I think the lightweight Pro ones last almost forever, so I've heard???
Originally posted by markp27
Coool! That means I'm something! Never been anything before
Originally posted by hmsracing
im using 3PK too. Love all the functions.
6 laps huh?
To check your crankshaft you can put it (the clutch end) in a eletric drill and lightly tighten it then turn it . Use anything straight for a reference as you are turning it. This method also works great for polishing it too. Note: don't try to use the crankshaft if it is in fact bent even slightly as it will damage your engine! Also I have a question for the serpant guys? Mine came with this oversize foam bumper and the bodys I build you have to really trim it Do you mind doing this or would you rather have a body made that would fit it?
Re: 6 laps huh?
Thanks for the tip with the drill - I had wanted to do this, but I only have a dremmel my crankshaft doesn't fit into it
I never mind trimming my bumpers - I had to do this for the 705 to fit the Stratus 2.1 I can always buy another bumper easily enough.
Man, your bodyshells are wild! RESPECT! You don't use a Mac, do you?
Originally posted by Sow&Steady
Not true ... MarkP is "MTX3-a**-kickier-on-first-nitro-race" man!
Originally posted by rodrigo1508
What radio is everyone using? I have a Jr xs3 but I want to change it. I have been looking to the 3pk and the ex-10 helios but dont know witch one is better.
Originally posted by crashed_1
Both me and Initial D are having big time rear wheels bouncing due to this...our outdrives have a deep dimple/scoop that binds the dogbones and limits its lateral movement... I've changed the right side 2 weeks ago and now it's the left that's giving me problems... Wished they made spring steel ones.
Originally posted by rjl
Any of you guys getting huge wear on the right hand diff outdrive? Is there a hardened one available?
It would be good if Serpent came out with the spring steel option. The pin in the dogbone will make a dimple inside the outdrive and cause the rear wheels to hop or jump when you accelerate. I believe this is caused by the dogbones getting trapped in the dimple and does not move freely. It will come to a stage when the rear suspension binds. So sometimes you'll find the rear end of the car just spinning off when you turn for no apparent reason.
Originally posted by InitialD
I've put the Helios in my hands with the antenna extended <ahem, ahem>. It felt really good and balanced than the 3PK I have. But then, you need to add an external failsafe when you use the Helios because it does not come with one like the 3PK.
Helios
Dude,
Where did you buy your Helios? Can't wait to get my hands at it.. I already puchased the wheel extension ... hahahhaa funny... coz the shops I went to didn't have em in stock.. out of stock..
Re: Helios
Originally posted by Titan
Dude,
Dude,
The extension is a must, it not only feels good, looks good too...
What servos are you using with the radio? I have a failsafe unit on the car and it's a little too safe...activates after about 10 tanks.
Re: Re: Helios
Ummm...Malaysia?
Ummm...Malaysia?
