Serpent 710
#8536
Re: Re: Re: Diff Assembly Fixed
Originally posted by BaxterC
Where did you get your Super Grease from, I have been trying to get from one of the LHSs here, but they keep trying to sell me some MIP Diff LUBE, which I bought, BUT, I didn't realise that the little tub had only enought to persuade a scale to move toward the 1 gram mark...
I got that grease from our LHS. Perhaps you could try emailing RCCarinternational or the other HK websites.
#8537
Re: Re: Last pieces of the 710 Jigsaw!
Originally posted by InitialD
Hey, get it up and done quick man. Seeing your pics is already making me impatient !
I fitted the engine last night - boy, I forgot how much I hate setting up the clutch! I only had to shim the thrust bearing with a 0.1mm shim.
Now all that's left is the fitting of the two servos and the RX unit
#8538
Re: Re: Re: Re: Diff Assembly Fixed
#8539
Re: Re: Re: Last pieces of the 710 Jigsaw!
Perhaps after some runs when everything else in the clutch settles in, you need to put more shims inside. This is what I found on mine.
#8540
Well, I couldn't resist doing some last night Supposed to be training for my bike races
#8541
Re: Re: Re: Re: Last pieces of the 710 Jigsaw!
Do you put more than 0.5 mm shim behind the brass collet near the front engine bearing? Did you tighten the clutch nut to the flywheel hard enough?
Good luck with those. That would take some time to get it perfect too.
#8542
Bike Races? Is that Bicycle or Motorbike?
#8543
Re: Josh Cyrul's servo of choice
Originally posted by PSI Racing
Hey D,
Here is Josh Cyrul's response to the servo question.
Hey D,
#8544
Re: Re: Re: Re: Re: Last pieces of the 710 Jigsaw!
I'm hoping with having the Sanwa servos it may go a bit easier - lets see
#8545
Mountain-bike and road-bike (bicycles) - I'm stupid enough to take part in mountain races, i.e. 250km with 5.5km of vertical climbing - these races take around 11 hours to complete. Takes quite a bit of training to get the fitness required and therefore I ride 60km everyday to work - even in winter when it is -20 Deg C!!!!
#8546
Re: Re: Re: Re: Re: Re: Last pieces of the 710 Jigsaw!
Let us know Mark.
Let us know Mark.
#8547
#8548
Re: Re: Re: Re: Re: Re: Re: Last pieces of the 710 Jigsaw!
You'll be with me every step of the way
#8549
Do they have other worst form of tortures that could have been invented than the ones you mentioned above?
This would really be classified as torture if I hadn't signed myself up for it!
#8550
Hey WOW... That must take some endurance... How do you manage in the cold... THAT is DEDICATION, Remember to tell yourself... IT ISN"T OVER 'TILL I WIN!!!... Helps me with anything I do.
Motivation isn't a problem for me - it comes down to self pride: I never give up. I can forget about wining these races, as quite a few of the professional riders take part - I've got no chance against these guys. Me best result so far is 120th place from 5500 starters - good enough for me!
