Serpent 710
#7021
Mark, thanks for the pdf file. Usually i have to scroll back few pages of this thread to find answer of which i knew someone had mentioned ...but now, i only have to refer the pdf printout. thanks. any latest news on D appearance...or something like that
If only u can put pictures inside the serpent 710 faq pdf...hmmm intersting...deserve some $$$ there.
#7022
We'll have to rely on our Spy to give further hints of his appearence and whereabouts!
Sow&Steady has provided some web space for the FAQ, so now I'm not limited to only 200k Bytes, it is now possible to add some pictures to the doc - but unless you have a good printer it may not print out so good.
When I get time, I'll look into doing a V2 document with pictures. Next big release will be the cleaning up of gramatical and spelling mistakes. Just waiting for a rainy day
#7023
I think this weekend, D will be very busy competing in our local race(well, actually their local race )[we same country, different state...bordered by big sea only ]
I assume he gonna try some big setup on the 710 and hopefully he'll be bringing us good news...like A main champion trophy this time ...
ok, ok, D...enoughlah to get B main champion this time...go go go make us proud.
#7024
Originally posted by Marcos.S710
or these if you have an on-road car!!
#7025
i should have won my final (rain only starts the last 10 minutes) ...i was leading while the rest engine died...left only 3 cars on the track...suddenly the race director stop when only left 1'45''. the rain was too heavy he said! ..end up 3rd(based on qualifying result!)
#7027
Originally posted by Profoxcg
does anyone have an M18? I got one last week; it is still in its box, but i want to make it fast enough to run with a stock electric touting car
#7028
#7030
Originally posted by BaxterC
What the .... RAIN TIRES??? this is a little bit new to me... I will have servos and electrics in the car that is worth around ~$200-~$250 even with the greatest waterproofing and fuel proofing, and with an engine that may not get up to temp on the track, there is no way you will get me on the track. Why would you? how do the cars run? dont they slide around because of the slick foam?
No reason not ot run in the wet. We do it most weekends . Like I mentioned a few posts back, a couple of balloons, a lot of red candle wax and silcone sealer will keep you totally waterproof. You can even get special waterproof jackets for your Tx allow we find a simple plastic bag and clothes peg does the same job
Although it restricts the power a bit an INS box on the carb airfilter will help protect the engine. But then who needs all that power on a wet track anyway.
#7031
Marcos.S710 and Mark:
JFYI, added yer site to my ever under construction website in the chosen links.jfc_tech website
#7032
Universal joint update!
I found an article that may clarify some things I failed to explain in the right manner in previous posts. (What can I say, I'm not teacher material )
http://www.indexgear.co.uk/hooke's_theory.htm
#7033
Super Moderator
#7035
Re: Universal joint update!
I think you asked for the term used to describe the SIN waveform? Anyway, its called Sinusoidal Pattern/Waveform.
Ignore if someone has already answered your question.
Cheers, Mark.
