Serpent 710
Old 03-18-2004, 08:56 AM
  #6256
InitialD's Avatar
Originally posted by markp27
I can't believe how quick those Border guys shipped my order - ordered on Monday and all the gear was here today! Respect!
More expensive or less expensive than the other options?
InitialD is offline
Old 03-18-2004, 08:59 AM
  #6257
markp27's Avatar
If I buy from my local dealer, he'd be cheaper, but in terms of other well known "mailers" about the same. But I couldn't find these parts (except the diff adj and the shock inserts) anywhere else.
Thought I'd give them ago. Good result.
Your PM is full again
markp27 is offline
Old 03-18-2004, 09:00 AM
  #6258
Herbie's Avatar
Thumbs up
Yep those guys are really on to it. Ordered on sundayevening and got my stuff deliverd today. Nice to see their teamdriver Rick Vrielijnck is also diong a great job for them ( 2e at the Winternats )
Herbie is offline
Old 03-18-2004, 09:01 AM
  #6259
markp27's Avatar
Where you at, Herbie?
I'll definately be ordering more from those guys - they've earned a place in the FAQ
markp27 is offline
Old 03-18-2004, 09:14 AM
  #6260
rodrigo1508's Avatar
how much upstop do you use with new tires
rodrigo1508 is offline
Old 03-18-2004, 09:16 AM
  #6261
markp27's Avatar
Hi Rodrigo,
Check out the FAQ section "Droop for larger tyres:" I've just posted the FAQ a couple of postings before yours.
All is explained there - if there is anything unclear - fire away.
Cheers, Mark.
markp27 is offline
Old 03-18-2004, 09:30 AM
  #6262
InitialD's Avatar
Just to make things clear, upstop and downstop are two different things.
Upstop is almost never used.
For downstop / droop settings with 66 mm new tires, +2 and +9 for the front and rear respectively interpolating from the stock setup of 0 and +7 in the front and rear with 62 mm tires. Both situations will be 6 mm ride height.
InitialD is offline
Old 03-18-2004, 09:31 AM
  #6263
Sow&Steady's Avatar
Originally posted by BaxterC
Julius... you are funny... just dont drink and drive... especially with them balls screwed...
I think you mean "don't drink and FLY"
I think Julius has been away from his lady too long.
Sow&Steady is offline
Old 03-18-2004, 09:33 AM
  #6264
Sow&Steady's Avatar
Default Re: COOL!
Just received my order from those nice guys at www.the-border.nl - super quick service!!!!!
Here's a pic of my new bits
woohoo Mark, no more wobbly shocks on your car for sure!
Maybe I need one too
  #6265
markp27's Avatar
Oops, I should read better
Did you mean upstops, Rodrigo? Upstops aren't usually used - I've never had to use them, at least.
Upstops are the screws which limit how far the suspension arms move in an upwards direction.
Downstops limit the suspension arm's downwards travel.
Cheers, Mark.
markp27 is offline
Old 03-18-2004, 09:35 AM
  #6266
markp27's Avatar
Default Re: Re: COOL!
Such toys - you NEED these things
It's a nice piece of kit - made from Alu and the pivot gauge has a ball bearing for smoother operation - NICE!
markp27 is offline
Old 03-18-2004, 10:10 AM
  #6267
Cheers, Mark.
HI, I do know what upstop means and I did ment upstop I was just wondering if anyone used it
Old 03-18-2004, 10:12 AM
  #6268
what I dont know is when I should use upstop and how much
Old 03-18-2004, 10:20 AM
  #6269
markp27's Avatar
I wouldn't use them. The idea is to stop the chassis bottoming out, so you could set them without your shocks on, so that they stop just before the chassis hits the ground.
I do believe, though, that they have a un-desirable affect on the handling if the suspension arms travel far enough upwards to the point where the upstops stop further travel.
Maybe a question for Julius - under what circumstances would one wish to use upstops?
Cheers, Mark.
markp27 is offline
Old 03-18-2004, 10:32 AM
  #6270
InitialD's Avatar
I did remember Julius or some team driver (Art Carbonnel) mentioning about it at mytsn. If I'm not wrong, you only use it when the conditions are very bumpy. Else do not use it. The upstop is set just enough to prevent the chassis from bottoming out.
Like what you say, it makes the suspension do weird things. The shocks hit infinity when the upstop screws are met.
BTW, there are no upstop screws on the 710 if anyone is interested. Just the front.
InitialD is offline
