Serpent 710
#6226
Tire Offset
Initial D, (and you other well versed Serpent masters)
Would any of you happen to know what the correct tire offset is for the 710?
Im about to order tires and do not want to be dissapointed by ordering the wrong ones...
Thanks in advance!
Thanks in advance!
#6227
Re: Tire Offset
Thanks in advance!
Thanks in advance!
fast tires,
new Arrows
speedmind
GQ(orange rim)
Take Off
all can fit in.
#6228
Originally posted by jfc_tech
the serpent includes the wrench(cross) to open, tight the wheel nut. I think its 5mm.
#6229
Re: Tire Offset
Thanks in advance!
Thanks in advance!
#6230
Re: Tire Offset
Thanks in advance!
Thanks in advance!
#6231
Re: Re: Tire Offset
Originally posted by GoldFinger
There is no right or wrong in offset terms. Its not black and white thing, just different. We still able to adjust it right.
#6232
Originally posted by cyba888
Im talking about the purple aluminum wheel hub, where the wheels attach onto it. I think your talking about the wheel nut that goes on the outside of the rim to secure it on the car? I forgot what its called but it also has a 1.5mm screw that holds it to the shaft.
#6233
I heard a VERY disturbing thing a few days ago... the Hudy Ultimate setup system and S710 are not compatible... Is this true?
#6234
#6235
Originally posted by Julius
The size of the alu hex is 10mm.
#6236
The wheel adapter hex that I measured when I got home is 12mm
You're right!!!!! it is 12mm
I edited my previous post.
Sorry
#6237
Re: Tire Offset
#6238
Re: Re: Tire Offset
Originally posted by InitialD
Zero offset is what you need. If you accidently buy offset tires, do not worry. You just need to re-adjust and correct the trackwidth by screwing in the pivot balls more deeply.
Sorry me bad
#6239
#6240
Re: Re: Re: Tire Offset
Yeah! let's screw the balls....
Sorry me bad
Sorry me bad
