Serpent 710
Originally Posted by captian
ha guys need some help is any body running outlaw with the 710? if so can you post some pics and any tips on running the loal body
http://3hobby.net/modules.php?name=c...3&cat=0&page=5
Nothing to it running the Lola body except that it is awesome and fast. Tips?
Just get a fast outlaw engine,
Use a one-way
Better to use the Loletta shell with the 710 or ..
get the low front shock tower and the Lola bumper.
If you want to use a guerney strip then you need to reverse the mounting of the rear body posts.
Get the setup right and depending on the track you will be keeping up even with the 1/8th cars.
Originally Posted by _cyclops_
So, i'm already warming up for the comming outdoor season here.. and i'm planning om making my car a little lighter. With the new rear diff being one of the improvements
Now what hop-ups or mods do you guys apply to the 710 to make it lighter?
- all titanium screws
- agree with you, new gear diff
- or the rear ball diff without the Al clamp but with ceramic balls
- run front one-way (locked mode if you have to)
- hollow rear shaft
- Al mid shaft
- No Al hop ups
- use the lightweight Al pulley holders (pulleys themselves are stock)
- Use the Mega engine (7 fins, light head)
- remove the radio box cover
- remove foam bumper
- change out all the Al hex that hold the pivot balls with teflon ones
- use any disc brakes with thousands of holes in it!
- run the smallest dia foam tyres you can
- drill lotsa holes in the chassis
- change the steering links to Ti
- don't use rear ARB if you can
- if not, use Ti links there too and the stock ARB
- Use an OS pipe (T202 I think?)... really light!
- remove the rollover protector (802138)
- use plastic shock bodies
- use only ceramic bearings ... all
- use only one coat, one colour on your body shell
- use 6v camera battery for qualifying (test for the right one!), normal batteries for final
- use Futaba S9550 servos
- use Ti pins for the arms (eg the 802226, replace them. Hunt around the Ti ones for other cars)
Happy?
The record? I've seen my friend's 710 weigh 1450 gms with 59mm foam tyres but without shell.
Now go to work and beat that!
Originally Posted by Dan D
What problems are you having? what do you need help with?
but thanks for asking
Originally Posted by Sow&Steady
If you are really serious about it .. then here is a go crazy way :-
- hollow rear shaft
- Al mid shaft
- No Al hop ups
Happy?
- hollow rear shaft
- Al mid shaft
- No Al hop ups
Happy?
Omg, what a list, should have asked before the winter eh :S
This is great feedback, and 1450 grams? OMG! that's amazing!
- Delrim pivot ball nuts are in already.
- Foam bumber is required (efra rules, but i'll cut something away )
- Mega engine is an option
- Already removed radio box cover
- Already have the lightweight pulleys
- Hallow Ti mid shaft
- Hallow 2speed shaft is comming up, need to deliver it to some handy dandy friend
- Disk brake is around here somewhere
well.. quite a list that i already have.. the TI scres saves 35 grams or so? I'll try does!
Thanks many again!
Browse through the album below for some pics.
Use a one-way
Use a one-way
ha sow&steady whats the link to the solid axle for the 710
why are you making the car so light? its not legal
Originally Posted by Pyramid
Nice.. plus VXR lipo 750mah RX battery including its 1amp regulator will take away additional 23grs over standard Nimh bats.
How are the Lipo packs in 1hour final? May like try them on RRR.
Thanks many again!
Thanks many again!
I think Cyclops is trying to get it down to the limit.
Yes, my car is 1760 or so, but i'm geting new servo's that are 10 grams more then the ones i have now. That would bring it to 1780....
That's too mutch for my likings, so i want to bring it back to 1750 or something... don't want it to be on the limit because other rims and the one-way make it lighter
I think the delrim pivot ball nuts should save me a few grams, the hallow 2speed will save me 10 grams and the new diff will also save me some... then i'll be looking for the ti-screws to get the rest down, some other ti-parts as well i gues
Who mades a decent Ti screw kit, which also itsn't overly expensive?
