Serpent 710
#2266
Re: MGs Race report
Originally posted by RobbyDV
http://www.mytsn.com/publ/publ.asp?pid=9430
#2267
Originally posted by InitialD
Any changes made to the car?
Here's the set-up:
http://www.mytsn.com/setups/setup.asp?sid=2188
#2268
Originally posted by Sow&Steady
Sorry to interject ... I personally love the Shark Outlaw. this after trying the stock EFRAs, NovaMegas etc. If you're an outlaw bunch of racers then try out this one out.
I assume you run in the foam class here in the UK as your using the Outlaw pipe, have you considered racing down at Brooklands? (next meeting Sunday 4th Jan) Having just received my Hudy tyre truer for Christmas I'm swapping over to foam but they tell me the numbers were down for foam at the last 2 meetings so we need to bolster some support.
Come on Sow&Steady you know you want to!
#2270
Re: Solid Axle
Originally posted by kreidel
Does anyone in the US have the pins needed to convert the one way into a solid axle?
SN
#2271
Winners Circle in Ga has the pins call 1-800-nitrorc ask for Lee
#2272
ups came 10 minutes ago...
#2273
What is there where web site number
#2274
Sorry but what is the website? Sorry at work and doing this can get confusing
#2275
#2276
First runs with 710s...
We ran our 710s yesterday.. Just 4 tanks of development and the car seems very comfortable on our local track now.
First off, the car is a WHOLE NEW EXPERIENCE from my piggish old impulse pro.. Feels (almost) like i'm driving an xray!!
Changes direction easily, forgiving when i come off the line (which is very often due to my driving skill!) and blinding fast even with my dinky 3port novamega (that hasn't been serviced since i bought it along with my pro about 2 yrs ago).
Our track is medium-large with a long str8, a wide sweeper and medium hairpins.. Changes made were minimal:
1) I dropped the speedminds for ellegis that came with the car... Btw, the rear tire does seems softer. After two tanks, the rear was worn faster too.
2) The diff clamp was completely loose at the start of the day and our diffs were still tight. However, it gets looser with each tank and the screw needs to be tightened again. By the 4th tank, the diff stops 'adjusting itself'. We ran it quite tight for the track. Made for awesome corner exits!
3) Running the front narrower than stock gave the car a tighter on-power exit. For the first 1 or 2 tanks, i nearly went wide into the grass each time i tried to gun out of the turns.
4) I had some strange black gunk buildup on the centre bearing of the belt tensioner. And my main belt was marked somehow.. (can be seen clearly in the pic) The rear belt turned a bit pale too.
5) Durability: Raygun had a couple of medium hits and the rear arm pivot ball pulled itself out. Definitely a weak point. He also broke a bit of his bumper.
I was rear ended by a 1/10 lola car (heh) but nothing happened. BOTH our DRS links were slightly scuffed by the 1st speed gear.
The bottom of my RX box was also a bit scuffed after a few slight skips on corner islands.
Overall, i don't think this car is as strong as the impulse and 705.. On the other hand, the impulse and 705 were built like M1 Abrams and NEVER took less than 4 tanks to inspire the kind of confidence we had after yesterday's run!
Good job serpent...
My car after 4 tanks:
Good job serpent...
#2277
Originally posted by Diesel Racer
How does that Shark pipe perform D compared to a matched pipe/engine combo?
However, with the 710, be warned to install the pipe / manifold carefully as the rear side pulley can touch the manifold because it's very long.
Anyway, with my kind of driving, I need a pipe that is durable as the shark inline ! The thing is really hard and it'll last a few hard knocks.
#2278
#2279
#2280
Re: Solid Axle
