Serpent 710
Impulse/705 chasis
Any mod. required for a 705 chasis to be used in an impulse? Any one experience?
Originally posted by InitialD
Well, I was testing different flyweight combos... On top of cutting the flyweights and mounting them in BETWEEN the flywheel post, I added two grub screws (M3 x 4) on each flyweights in the respective holes as pic below to make them heavier.
There are others who mount the flyweight as per the manual but add one M3 x 4 grub screw on the end of the flyweight.
Anyway, as what Pyramid mentioned, I found the performance using two grub screws per flyweight a little too "heavy" for my liking and at some points will drag and bog the clutch engagement.
So now, I took out all the grub screws and run the cut flyweights just mounted in between the flyweight pins.
What's everyones opinion now on using the longer servo saver with less Ackerman?
Steering has improved since I used it. Only did a few tanks so can't say for sure yet. But initial feel is that steering is more "predictable". Turn in is also better, I feel...
I reduced the steering travel a bit after installing the longer servo saver and the car turns well and less likely to lose it's rear end. Just my opinion...
And the friction collar that came with the servo arm is a lot better than the stock one. I managed to find an extra collar for my rear diff too...
Re: Impulse/705 chasis
Danke
Danke
Re: Re: Re: titanium screws
I do have problem finding the 2 long M4X25 flanged screws(1019) at the front bulkhead in titanium though...
If you can get countersunk ones, that would be good. Use the countersunk shims with the countersunk screws and you solve the problem.
The thing is it's difficult to even get M4 size titanium screws. I wonder if the East titanium screw set for 710 has those screws in titanium or do they only include M3 screws in titanium...
Ihr Willkommen.
Ihr Willkommen.
Re: Re: Re: Re: titanium screws
Originally posted by markp27
*cough* you meant, "nichts zu danken" - obviously too early for you D,
Re: Re: Re: Re: Re: titanium screws
You should buy some and find out
D, you got time to do an experiment for me? If you do, could you do the following:
remove the metal shielded bearings and end-play shims from you clutch.
Now add shims to the thrust bearing carrier until it can no longer be pushed/pulled. Using your verniers, measure the shims which had to be added to achieve this and compare with your measured clutch gap.
Cheers, Mark.
Cheers, Mark.
Re: Re: Re: Re: Re: Re: titanium screws
Somebody else should do this... <hint, hint>
