Serpent 710
Will Jaco nitro shoes fit as well?
if you were not always lounging around.
and working on your car more like this brief moment.
that may happen
that may happen
okay eric must of used our laptop in florida and it left him logged in, now that I have logged him out and me back in repeat on the above post.
Originally posted by IndyPhil
Hello Guys. I am a Offroad driver (mod buggy) and can wheel and am looking into getting into Nitro onroad 1/10 this summer. Looking at the Mugen prospec and the serpent 710. Looking for your input into what car to get and if parts are a issue USA. I hear the tc3 breaks alot so dont want that. Also what would I need to get other than the obvious stuff. Like most commonly broke parts. What engines fit (Sirio .12 EVO 2 , 3 Port ?) can get one free. Any help would be appreciated.
1. Serpent 710
2. Kyosho RRR
Mugen MTX3 is a good car ..but i think the new model will be soon coming out !!
Originally posted by fmolzer
He got to go home with a trophy... He gets me every year
2006 will be mine though
Originally posted by sparksy
Hey D...
Sorry I didnt get a chance to look you up while I was there. I'm back home now and about to rebuild the snake. Anything important I may have missed over the last 3 months? I'm way too lazy to scroll back a billion pages...
Hey D...
3 months? Ummm, low friction belts, 21T aluminum side pulley... Nothing much.
The car is already race ready out of the box. But if you want the aluminum blings, you can go ahead and look at www.mytsn.com/products and look at the new 710 items released like the mid aluminum bearing block, X bar radio tray support, one piece engine mount etc.
The performance upgrade that you should get and try on the car is the new servo saver, the new style diff clamp (you may receive this in the new batch of the 710 kit), the rear 2.5 mm or 3 mm sway bar, the softer red shock bladders, red springs (front and rear and perhaps blue springs), 35wt / 40wt Serpent shock oil to play around.
Part wise, depends where you are in the US... Do you have any LHS around that stocks Serpent parts? If no, then do you want to rely on online websites to provide parts for you? What about the local track support where you will be running the car? Those are the things only you can answer...
If you have any question, just shoot.
I know the new servo saver has been asked. I would appreciate if you can quickly tell me what's the diff over the old one? I run on a med/low traction track meaning traction roll unlikely. FYI, I did try the 2.5mm rear bar - too stiff and not enough traction for me.
Thanks.
Originally posted by TitaniumR
Hi D,
Thanks.
Hi D,
Thanks.
What problems are you having with the 2.5 mm rear bar? The rear spinning when coming out of the corner? Try a harder front sway bar setting with the 2.5 mm rear sway bar...
Engine Problem source found.
Fmolzer and Ammdrew found the source of my engine problems after the end of my main:
The engine demon really kicked ass!!!
Originally posted by markp27
Well, you shouldn't feel too bad Fmolzer - you and Ammdrew suck, but I suck and blow
I guess you came back thinking you never played so much RC in your life eh?
Hey D...
Hey D...
Cheers, Mark.
Re: Engine Problem source found.
