Serpent 710
Originally posted by InitialD
Of course MrChan makes sense... He's number 3 driver in Thailand after Suruth and Surikarn.
Originally posted by MrChan
Most of time, my car is always a bit understeer.. I like this way
[B]To tell you the truth, all of them including the Italian guys use the same method ! They put one palm of their hand on the headsink heat to gauge the heat when just starting. Seemingly I think that's like a feel thing to gauge the heat build up before they start to rev the engine and mess with the needle. And like all pro tuners, they listen to the engine purring. No temp gauges needed.
But seriously, the engine ran smooth during warm up. No engine cut off. And that's right after break in. Only the stupid receiver pack spoilt the day for me (another long story). So DNS for me (or rather I recorded only 1 lap) on the second and most crucial heat.
Originally posted by markp27
[B]Would you be able to repeat this now or is it really a feeling thing?
There's always next year when you can also kick a couple of old guys' arses
Hey D, do they have zoom at the track?
Originally posted by GoldFinger
...EXERGEN on the back of lowest heatsink)
Originally posted by Sow&Steady
DNS? You mean DNF right ...
Just before the heat started, I found out my radio was in fail safe mode. Back in the pitlane to check while the cars all zoomed off to start the heats. I think after about 3 minute or so, I tried to run again to see if it's still something wrong and that's when I only registered 1 lap if I'm not mistaken and the same problem occured. That also because the transponder line is on the left side.
And at what diameters ff/rr?
57.5 mm front and 58.5 mm rear.
We need to sort out this traction roll thing ... I mean, which part is most sensitive to adjustment that prevents traction rolls without compromising the car's set-up.
The grip must have been really really high for the car to traction roll with these diameters. Did you use your usual set-up or a lot changed?
Will put out my setup soon...
Below are some proof of it...
Originally posted by crashed_1
Me too... At least you managed to finish your main...
I did not finish. Had a bad pitlane issue with spectatorsss.
But it was Fun which is good enough for me.
Originally posted by kitracer
My god, can't keep up with you guys....more than 1 page a day.
... Check with Uncle Crash. He has the most experience with it... And he consulted the Miester and he gave him some good pointers.
Kitracer, in the good old days - when Sow and myself were young ( ok younger) - we'd get through 6 pages a day
Obviously not a Messiha.
What does it mean ?
