Serpent 710
hey initial D
yep, I used to have some 3racing 1+mm offset hubs in the front.
Well, I cant wait till i have a little money left over !
Re: hey initial D
I only use the spacers when I use Speedmind tires and I do not use it when I use Ellegi tires. That way, I do not need to twist the pivot balls in and out to set the different trackwidths when I switch tires.
Plus using the spacers with Speedmind rims, they do not rub the end of the plastic ball steering link. They do rub if the spacers are not used. Ellegis no problem rubbing.
Re: Just bout a 710
Originally posted by nitro al
Just bought a 710 and finished putting it together last night. I just read the discussion on 3Hobby's forum "710 Included tools" and I didn't get any of the 'additional' tools listed ... Centax clutch holding tool (new) or the Two-Speed Gear removal tool (new).
Are these included in all new kits or just for overseas?
Al
Al
Where did you get your kit from? If you got it from your LHS, perhaps you could have gotten a slightly older batch kit.
Did you get a black coloured flywheel? What about the rear shock tower? How thick is it?
Re: Re: Just bout a 710
Originally posted by InitialD
Al, no idea. I believe there is no distinction between local and overseas packaging. All should be the same.
Check the colour of the flywheel...black = new
TSO shocktowers and lower rear arms
what is a TSO ?? is that bad?
The Same Old
Im confused
Im confused
The new kit he got apparently had The Same Old rear shock towers and the The Same Old rear bottom arms that have less plastic at the end to grab the pivot ball when screwed in...
The newer rear shock towers are thicker and if you buy a replacement, you'll definitely get the newer thicker rear shock tower. As for the rear bottom arms, if you buy a spare part replacement at your LHS, they all are new and appear to have more plastics where they can have more surface area to grip the pivot ball threads.
yeah ok so its bad hahaha
sorry guys, a little slow here
thanks D
thanks D
i have 6 painted, mounted prepared and ready to race serpent bodies for sale. 4 mazdas and 2 stratus 2's
selling them all as a package winner takes all
all have internal re-enforcemnt supports, check it out and bid here: http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5947742690
Uncle Crash is speaking in riddles !
Preparing for something ?
Originally posted by GoldFinger
New kit huh ?
New kit huh ?
So have you broken in your engine yet?
Nah... For me the same old one. Uncle Crash got a new one a few months back.
Has not coming yet
Great !!!
Has not coming yet
Great !!!
Has not coming yet
