Serpent 710
Originally posted by InitialD
I use blue threadlock. I also use a longer grub screw in place of the short ones that were given.
I didn't really even knock the car much at all as I'm very careful and slow. Both upper arms are equally loose. Rest of the arms are fine. Guess I'll fit in new arms after this sun's race - my first 1/10 race.. if I decide to join... and see how they hold up again.
Originally posted by Pyramid
Try this Goldfingers method, apply a bit more of thread lock to the grub screw, screwed it in and take it back out. Let the thread lock dry by itself on both parts then install the grub screw again.
Originally posted by markp27
Quick you are today, quick are you
Originally posted by daniz24
Hmm, I prefer to call them Horny Face of The Year btw, where is Goldfinger??
There you go, the tallest guy. If you notice, always having a cigarrete either on his mouth (GQ cup) or hand (this pic)
Originally posted by Sow&Steady
As long as his car is smokin' as well then its OK I guess!
I am concidering running a 710 for next season , right now I have a fac team NTC3 its OK but needs alot of attention to keep it in top form .,IS there any common issues with the 710 ? Any parts prone to breakage , the aluminum pillow balls concern me since the steel AE ones seem to bend easily , how good is parts availability and customer support in the USA , does it require any upgrades for relaibility or performance ? Sorry for all the questions but want to make the right choice since I am going to commit to some bigger events for next year .
The diffs? When you greased the balls well (Mugen Super Grease), they last very long and smooth. I have not needed to clean and service the diffs for a pretty long time already and they still function the same. They belts and pulleys also last very long. I would say much longer than some other cars out there. The Serpent pulleys and belts on the 710 are second to none.
The aluminum pivot balls are tough. I've not bend one yet after over a year of playing.
Parts availability? Where are you at? Does your track have a hobby shop that carry Serpent parts? You could always mail order if you choose that route. Else, contact www.serpentusa.com for more info.
If you get a new 710 kit, they should already come with all the necessary updates from the manufacturing changes made to the car like harder front and lower bumper, black flywheel, rear ball diff adjuster and clutch tools included.
As for other updates, you may want to get the thicker rear shock tower that should come with the same part number as a spare, the lower rear arms (longer at the edges where the pivot balls thread in to get better holding) and lastly the yellow Centax clutch shoe.
As Julius mentioned, the best upgrades for the 710 are the rear thicker sway bars (2.5 and 3 mm) and the new longer servo saver. You may want to get the harder red springs (stock is softer yellow) for the car if the track permits. If your track is tight, you may want to go with the lock pin set to lock the front oneway bearing of the car or get a front adjustable ball diff.
From then on, you may want to add some hop ups slowly like the engine monoblock, the aluminum radio support brace, aluminum shock bodies, the aluminum mid bearing block, lightened mid bearing shaft, aluminum front sway bar holder etc. But mostly, the car works superb in stock form.
Nice write ups D, hope to see you in Bangkok..
Just dont forget to register already 52 now and I tought you wanted on 18
Well, I knew that I could not get 18, 28 or 38. Maybe I'll land at 58.
oh no no Bro, 58= 13 =4
Forgas State Race
Sup guys ,MARK ,D,my 710 brothern been busy ,how is everyone,got a state race this weekend ,i will be running a modified ns3 race, with the new powermax ,header an pipe combo,an will be trying out the rd logics cvds for the frt.The race will be held at the kissimee track, I raced there last month running frt an rear balldiff ,it worked perfect.So tell me whats new out there for our 710s.Oh i seen some rrr out there, they are really fast.
Thank you for the Info , yes I do have a local hobby shop that carries some Serpent parts .
You mentioned updating the servo saver , what is the difference and is there an issue with the kit one ?
How does Serpent customer support compare to other brands ?
