Serpent 710
Originally posted by Picard
that sounds good how long are your heats.
Was that 2mm on the fronts for the whole day?
and the track surface was still new 'bituminous asphalt layer' that must have contributed to the minimal wear..imo
might i add that i'm not an aggresive type of driver ... i stick to my line ...full throttle ,release throttle...in or out of corner..then full throttle again...rarely use my brakes too...esp with the fr one way
5 minutes per heat...and yes it was 2-3mm on the front for the whole day.
how should my gear mesh be?
Originally posted by sparksy
Well I ran the new servo saver on the weekend. I realy like it.
I ran the highest front roll center and red springs allround and 30wt snake oil. Man did the car turn. Very fast to react and held mid corner speed nicely... washed a bit of speed past mid corner. I think through too much grip.
Switched to 40 shore all round (up from 35's) and the car held corner speed a lot better.
More testing tomorrow...
Yeah Sow... I'll stitch one together.
Pitty I've run out of room on 3hobby for image upload... (hint hint)
Dandynong Track.
Not the best stitch but it will give you some idea...
Post it there in a few minutes.
Note that you can post it to the "Public" album without using your own quota.
Dandynong Track.
Dandynong Track.
Originally posted by Sow&Steady
You only need to ask mate.
Thanks Sow
ahh... I'l wack it in the public album then.
Thanks Sow
Thanks Sow
cheers
Yup ... I "teased" him just now by inviting him over to the house and letting him see that you guys have talking behind his back.
Mind you, I nearly went into the fence when we were both on the straight and your 5 port thingy blitzed past my little JP FX 3 port - an impressive amount of power has that 5 port
