Serpent 710
Re: Re: Re: Re: Re: Re: Tires
Originally posted by markp27
The front right looks a little coned from here - not sure about the front left?
Make sure you adjust the camber so the fronts wear evenly across their width.
That is a bit strange with the left front, though - are you using a locked front axle?
Re: Re: Re: Re: Re: Re: Re: Tires
Originally posted by Brett.w
So swap the fronts every tank?
P.S what the new shock tower?
There is a new thicker rear shock tower availble, as some found the original one a little too weak in a crash Unfortunately you and I seem to have got a defective original rear shock tower which refuses to break
Fronts seem to be pretty even and iam running a oneway on the front not locked.
Re: Re: Re: Re: Re: Re: Re: Re: Tires
Well it can't be from braking, then - is the one-way working ok?i.e. both wheels spin ok in one direction and drive the drive train in the other. I would think it is ok, otherwise you'd have problems under acceleration.
chasis
Whats the difference between 3 Racing Aluminum Chasis and Serpent Chassis 4MM for 710 ?
I'm about to order some parts from rc-mushrooms.
Max
Max
Oh matey, you can have the choice of one of the ones I know
Originally posted by rwisejr
Hey he may get out because they may deport him. You know Old guy with jedi mind tricks !!!!!
[B...He'll be using all his Jedi mind tricks to get rid of that girl's boyfriend tonight [/B]
Re: chasis
Max
Max
By the way, purple is passé.
Re: Re: chasis
Originally posted by KevinS
With 3racing's reputation on their aluminum parts and the Serpent chassis being less expensive at Mushroom, I would go for the original Serpent chassis every single time.
Re: Servo Saver
Originally posted by jag
Is the part number for the new servo saver the same as the old one?
Does any1 know where i can get it?
Max
The problem is that they dont have Serpent chasis in stock
Max
Max
I think when you hit "Notify me of updates to Serpent Chassis 4MM for 710" to the right of the product description, you will get an e-mail when it's back in stock.
Optional Servosaver Arm
So who has fitted this? Has anyone else found it causes the origional part of the assembly (the arm that the servo link attatches to) to hit the left hand bulkhead?
Oh, and if you havent seen it....
Aluminium Middle Shaft
Re: Optional Servosaver Arm
I suggest sticking with a Ti one.
