Serpent 710
Originally posted by sn4il
Hehe. I live 4 blocks away from Bruckner Hobbies. Where do You guys drive Your cars?
I was told that Im not allowed to drive over Whitestone because of that accident I was planning to go to Orchard Beach this weekend.
Max
Max
anyone every go up to middletown ny to race?
Originally posted by Bxclip
does this look correct or is the brake theign surpsoe to be at a 90 degree angle?
what is the replacement rate of the yellow clutch... it feels pretty soft (as clutch shoes go).
I have actually not replaced the clutch shoes yet since I got the car this year. Black or yellow. But I have heard of people melting them. That is because the clutch is not set correct enough which then causes the clutch and engine to overheat.
Originally posted by Sow&Steady
It seems they last a good 2 full races (3-4 heats and mains), so it they're truly low-friction, I'm willing to try just to beat Mark.
I think Mark is preparing some special stickers at the rear end of his bodyshell which should read "Eat my (tire) dust" or "Catch me if you can".
Originally posted by InitialD
Yeah looks fine. As long as the brakes does not engage (unless you intentionally did it to get drag brakes) and the throttle servo is not strained, it should be ok.
Re: hey SOW & STEADY
Originally posted by impalabob64
Bobby here i only drive serpent know,it is the car for me, raced at our lhs fastest lap with 710 14.9 an won the A main 53 laps 15.09 SERPENT 4EVER.
Re: Re: Monoblock
Originally posted by 840918001
For single races like the upcoming worlds it will not be "nesecarry" , because the team drivers all have some completely new chassis with them. If Micheal Salven thinks the chassis isn't good anymore, then he will just take a new one.
From wath the dutch teamdrivers told me about the part, is that it will make your chassis more durable and protected against bendeing, as well as the carter of your engine.
The backdraft is that it will aid some extra weight to your car, but that is for most drivers no problem.
Anyway, talking about the worlds in Brazil, I believe from Team Serpent Holland, only Michael is going?
Yellow clutch shoes soft? Their material is harder than the stock black one.
i have yet to take the black on out since the original install... just that the yellow felt a little softer than what i was expecting i guess. thanks D.
is the melt down generally caused to the nut setting being too loose or too tight in the clutch?
Serpent 4ever!
Getting desperate?
Getting desperate?
Anyway, next experiment ... JP RED shoes.
New 2.5/3mm rear bar
Wow, this thread moves fast!
I noted somewhere Sow and some of you commented on the new thicker bar. Appreciate if some of you can lead me to more info on how it works in advance to my testing this weekend. I'm trying to get more on power steering with these since the rear is so stable. An anticipating that my JPS5 will be weaker than my Max15, the thicker rear bar may help alot to throw the tail. Thanks.
Re: New 2.5/3mm rear bar
I can tell you that there has been some feedback on the thicker roll rear roll-bar. Apparently at the recent sedan nats in Toledo, the Serpent drivers actually used these harder rear roll bar to REDUCE steering and hence cured their traction roll problems.
They feel that with their particular set-up and the high grip track, they needed to prevent the rear part of the chassis from rolling in order to reduce front grip. Strange but that is what I heard.
As for you test. If you're looking for on-power steering, the first thing to try is to increase caster.
