Serpent 710
Suspended
Re: Re: one piece engine block
Originally posted by Blue Sky
Anyone got a picture of it? I can't find it on the Serpent site. Thanks.
Originally posted by packetdreamer
that must be the optional rear swaybar?? is it adjustable by that screw in the middle? or some otherway? what is it's part number?
thanks.
thanks.
Partnumber for the whole set (2.5 and 3.0mm) including mounting hardware is 802337.
Originally posted by Sow&Steady
The indoor track where I race from time to time is very falt and smooth, I've tried 4mm ride height there and even with yellow springs and 30wt, no issues with bottoming out.
Originally posted by markp27
Which dog bones is he using at the rear - they are hudy steel?
Hi I am running a set up that it is very good for me, but I am using front & rear tire 40, what happens is that the rear tires wears faster of course than the front, I will like to change to 40 front 42 rear, what will be the change I have to do, from the following SET UP I have.
At the moment I am running in a small track with high traction very tecnical
Suspension geometry Front:
Downstops: 0 mm
Set-up ride height: 6.5mm
Camber Left: -2 degree
Camber Right: -2 degree
Track-width: 197mm
Toe-in: -1.5 degree
Caster setting (mm in front): 3mm
Roll-center position upper arm (mm): 0 mm under
Upstop (mm):
Suspension geometry Rear:
Downstops: 7mm
Set-up ride height: 7 mm
Camber Left: -3.0 degree
Camber Right: -3.0 degree
Toe-in: +2.0 degree
Track-width: 198mm
Roll-center position upper: UTI
Roll-center position lower: LT
DRS arm position (low-mid-up): level
Shockabsorbers Front:
Springs: red
Oil: 40W
Holes: 3
Cilinder type: alu
Shock-tower position: 2nd hole
Shockabsorbers Rear:
Springs: red
Oil: 45W
Holes: 3
Cilinder type: alu
Shock-tower position: 1st hole
Lower shock position: outside
Anti-roll bar front:
Thickness: standard
Position: flat
Anti-roll bar rear:
Thickness: 2.5mm
Position: 2mm from end of bar
Position on lower arm: outside
Tires Front:
Make: Ellegy
Hardness Left: 40 shore
Hardness Right: 40 shore
Diameter: 64mm
Wear in 5 min. Left:
Wear in 5 min. Right:
Tires rear:
Make: Ellegy
Diameter: 64mm
Transmission:
Pinion 1st: 17T
Pinion 2nd: 22T
Gear 1st: 60T
Gear 2nd: 55T
Front axle:
Type: Ball Diff
Diff. setting: Soft
Rear axle:
Type: Ball diff
Diff. setting: medium
Aerodynamics:
Body: Alfa
Wing:
Gurney strip:
Engine and pipe:
Engine: Nova Rossi NSR12 S3
Version:
Head shims: 0.4mm
Glowplug: 6TF
Pipe: Novamega
Header:
Length: in-line
Fuel: 20%
Downstops: 0 mm
Track-width: 197mm
Toe-in: -1.5 degree
Upstop (mm):
Downstops: 7mm
Toe-in: +2.0 degree
Track-width: 198mm
Springs: red
Oil: 40W
Holes: 3
Cilinder type: alu
Springs: red
Oil: 45W
Holes: 3
Cilinder type: alu
Thickness: standard
Position: flat
Anti-roll bar rear:
Thickness: 2.5mm
Tires Front:
Make: Ellegy
Diameter: 64mm
Tires rear:
Make: Ellegy
Diameter: 64mm
Transmission:
Pinion 1st: 17T
Pinion 2nd: 22T
Gear 1st: 60T
Gear 2nd: 55T
Front axle:
Type: Ball Diff
Diff. setting: Soft
Rear axle:
Type: Ball diff
Aerodynamics:
Body: Alfa
Wing:
Gurney strip:
Engine and pipe:
Version:
Head shims: 0.4mm
Glowplug: 6TF
Pipe: Novamega
Header:
Length: in-line
Fuel: 20%
Re: Re: Re: one piece engine block
Give me a couple of days and I'll have it in my hand - photo will be on its way
Originally posted by sparksy
Thats all I did... just enough to free it up, without taking aluminium off... just the anodising.
Re: Re: Re: Re: one piece engine block
Thanks Mark!
Thanks Mark!
lay down throttle servo conversion??
is there one available? where can i get one? and what brand is it?
Re: 710 German Champion - Michael Salven
Well even though this was at a track only 3/4 of an Hour away from me, I didn't get to see it due to other commitments Check it out though, Serpent 710 1,2 and 3!!!!!!
http://www.mytsn.com/news/publ.asp?pid=10624
Re: Re: 710 German Champion - Michael Salven
Aww man! You should have been there, then you could have stolen Michael's car!
Re: Re: Re: Re: 710 will defitely go even quicker now!
Originally posted by Diesel Racer
Wish I could but as you saw on Sunday I'm not quite quick enough, and with the move to Spain I just won't have the time but most importantly the guvner won't allow it.
Moving to Spain? Wow! Good ... open a track there and we'll visit.
As for Guv' that's easy ... just entice her to Florida sun and beaches!
The Serpent one looks too plain.
Originally posted by SERPENTFREAK69
I DONT THINK ITS UP YET....
