Serpent 710
Originally posted by markp27
On power the one-way is different to a solid, in that it allows one wheel to rotate faster than the other. The slowest wheel is always driven and the faster one freewheels.
unless it loses grip, at which point it momenterally rotates faster than the outside wheel and at this point the outside wheel would be powered - until the inside wheel once again rotates at a slower speed.
Once outside wheel is powered, both inside and outside wheels will be driven at the same time and the inner wheel will continue to slip controllably following the same outside wheel spin rate.
Originally posted by nitro rookie
Also the thrust bearing for the centax clutch, is there anybody else that makes one to use. My hobby shop won't order from serpent unless I place a $150 order.
Else, if you know a shop that carries Mugen parts, the MTX-3 uses the same thrust bearing size as the 710.
Or if you know of any shop that specially sells bearings, you could get them to order for you 5x10x4 thrust bearings.
Thanks for the help Mark and IntialD.
My hobby shop can get the Mugen parts for me usually in a couple days. So hopefully I can have one by Friday.
I can see this centax is going to take some getting used to.
I just put the car together last week and ran about 5 tanks thru it and then it started acting up. I'll order a couple of them until I can get it worked out. Beside I like spare parts. I'll try and post a picture when I get it back together.
Originally posted by InitialD
Correct. I agree with you there. But like I initially said, it happens only in the beginning. Once the inside wheel slips on continuous power from the drivetrain, both inside and outside will lock and will have a tendency to continue to spin at the same rate.
Correct. But I think that happens only on an ideal situations where you do not get any slipping in the inside wheel which is impossible because the outside wheel gets more pressure than inside wheel due to the turning.
Originally posted by GoldFinger
Interesting, that difference action is due to amount of throttle and steering applied. These variable will changes the traction amount from outside to inside tire.
Originally posted by Sow&Steady
Gosh! You and Mark are just alike, only Mark gets rich girlfriends and HE has their credit cards!!!
KHM?
KHM?
Difference in steering input creates different inner and outer tire circle radius and therefore creates different wheel spin rate on outer and inner wheels.
Mark, clearly you do not have the ring.
... I gently accelerate out of a corner...
Trying to play Jedi mind tricks on Mark is it?
D do you have to regularly clean the two metal shielded bearings in the centax? I keep having problems with mine - my end play is fine and I have no problems with the thrust bearings, but I keep breaking the shielded bearings.
Maybe I don't clean them as often as I should?
Anyway, I don't clean those bearing regulary. If they are grittless, I let them be. I use them new without degreasing the bearings. I find they last a lot longer at the expense of some smoothness. I thought I did mention this earlier that I degreased all my bearings except the small ones that goes into the clutch and the flanged bearing that goes into the 2 speed hub.
The other reason why I don't degrease and put thin oil in those bearings is because they do more harm spitting out oil excess into the clutch bell which can affect performance.
If you really need to oil them because they are dry, try packing light grease into them and clean the outside.
