Fuel Injection?!?!? >
Fuel Injection?!?!?
Fuel Injection?!?!?
Old 10-27-2003, 01:01 PM
vtl1180ny's Avatar
Smile Fuel Injection?!?!?
Could this be the wave of the future for cars too???
Imagine not having to screw with needles anymore and having a perfect mixture???
Sign me up, I want one... Preferably a .12 please...
ROAR will never go for it...
OS Engines
vtl1180ny is offline
Old 10-27-2003, 04:43 PM
RCTech Member #2
TSR6's Avatar
Have you seen the cost?
Tower has it listed as $999.99, which very few people would go for.
TSR6 is offline
Old 10-27-2003, 04:51 PM
vtl1180ny's Avatar
I remember when VCR's for $4,000....
Imagine having control over the fuel curve??? Wanna lean out the top end... Richen mid range... Possibilities are limitless...
Both my fuel injected motorcycles have Power Commanders, its great to be able to plug in my laptop and play with the fuel mixture without getting dirty... Beats changing needles, seats, float levels... I'd pay for the same on my RC's...
With the money I spend on RC's, what's the difference...
Old 10-27-2003, 05:47 PM
will it fit a .12 or four stroke?.......
mtx3racer is offline
Old 10-27-2003, 09:03 PM
ill stick with the regular carbs myself...i like playing around with settings and its alot less exspensive to turn a screwdriver
2mcgrath is offline
Old 10-28-2003, 02:06 AM
Thunder racer's Avatar
MATE YOU GOT THAT RIGHT
playing with the mixture is all part of the fun.
Thunder racer is offline
Old 10-28-2003, 04:40 AM
Default Fuel Injection
This is not new to the world of rc cars !! About 10 years ago I believe racer's choice had a unit similar in appearance to the one in the picture and it automactically adjusted fuel air mixture based on demand and weather conditions. Check on the web if you can find speedline phone number they might have some old units left.
nitrohead5300 is offline
Old 10-28-2003, 05:27 AM
Trader Rating: 15 (100%+)
I run the unit from pc/rc. It works great. I get double the fuel economy. I get 15 min out of one tank on my 1/10 stadium truck. They went for $159.95. I have some extra brand new units if anyone is interested for $110 shipped. I have been using mine for 2 years now. If you are interested you can email me directly at [email protected]
It is ROAR Legal and it works great on my .12
seajj2 is offline
Old 10-28-2003, 05:29 AM
Hopefully the picture will show up
seajj2 is offline
Old 10-29-2003, 05:54 AM
vtl1180ny's Avatar
Fuel economy is one of the big plusses to a system like that, a bit more HP is the other plus... But the biggest advantage to it is always having the propper fuel mixture...
Old 10-29-2003, 06:29 AM
How is the fuel pressure controlled ?
In order for a fuel injection system to opeate correctly it must have a constant fuel pressure.
The fuel pressure on a nitro changes with rpm.
Bob The Builder is offline
Old 10-29-2003, 09:48 AM
Francis M.'s Avatar
i'm guessing injector pulse width thats how most programable injectors are programed.
Francis M. is offline
Old 10-29-2003, 12:42 PM
vtl1180ny's Avatar
I'm going to assume since I haven't seen the system up close that it's more comparable to a throttle body setup... The fuel is still being delivered the same way, there's no direct port injection... You only need slight pressure to feed the fuel, it's only taking care of the metering...
Old 10-29-2003, 04:31 PM
Correct it is more like a throttle body. Same concept.
seajj2 is offline
Old 11-01-2003, 09:30 PM
All I need is a unit that can hook up to my reciever and allow me to set the mixture with my 3pk while driving. That would be so sweet if you could rig that up. It would also be sweet if they could make one that could moniture temperature and adjust the mixture to compensate automatically. That would be my dream, just turning a few dials on my 3pk rather than going up to the car to make adjustments with a screwdriver. It actually seems like it could be possible. I think the 3pk already has the capabilities to do that, youd either have to design a new reciever or find a way to adjust it using the third channel and make the unit of course. I cant believe nobodys made one of these yet (well in recent years).
seajj2: are those two things attacched to what look like wires on it needles to replace the stock needles on the carb?
AE Racer is offline
