Old 03-04-2011, 03:03 PM   #1456
The engine is a Novarossi kangaroo, Its very difficult for me to explain the 0.8 spring, a measure the top of the crank to the start of screw, and apply there a Zero point then i measure to the top nut that press the spring and got there my measure, (if you understand me)
I will try the 10mm measure but already burn 2 clutch, so i fear that it will not work.
Thxs
kavajas is offline   Reply With Quote
Old 03-04-2011, 03:11 PM   #1457
M7H
M7H's Avatar
Thxs
Yes, I understand what you mean. Then 0.8mm seems ok, I have gone further than that....
Really have no idea why you seem to burn clutches!
Are the flyweights moving free over the pins, or are they binding?
Serpent
M7H is offline   Reply With Quote
Old 03-04-2011, 03:17 PM   #1458
They were new ones, maybe not as free as it should be, but i never think that could happened,
So thats the best and the top performance clutch to use?
Old 03-04-2011, 03:25 PM   #1459
M7H
M7H's Avatar
Can you maybe take the time and make some pictures of your clutch?
I can only think of 1 thing I have seen before and that is that you have installed the plate the other way around....
Serpent
Old 03-04-2011, 03:29 PM   #1460
Will try to take some pictures.
The only thing i change was i put the original flywheel shoes, same gap and it works until today.
Old 03-05-2011, 11:51 AM   #1461
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
[QUOTE=M7H;8744799]The video is correct, I don't know what you mean with left and right hole, we are confusing each other.
These are the holes which must be placed over the pins.
ok after reading and watchint the video i took my apart and my weights don't have holes on the right just on the left also looking at my manual its the same...do i need to change them???
These flyweights where never meant to be put in between the pins, who told you that?
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 03-05-2011, 12:03 PM   #1462
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
The weights in the video and in the pic are the optional ones.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-05-2011, 01:02 PM   #1463
Winner's Circle's Avatar
Thxs
Has your clutch ever partially thrown a centrifugal weight out? If it has, then your problem could be a bent clutch bell. If the bell is bent even a little it will eat clutch shoes.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 03-05-2011, 04:09 PM   #1464
Lee
Hi there Lee, i know what you mean, i dont know after burned out i switch to the original flywheel weight, i put a new bell on. I notice even wen you apply new bearings on the clutch,(everything new) still have some play to the sides if you know what i mean.
Itīs raining this weekend no change to give a try.
Even so thxs to all the help around here.
Best,
Old 03-06-2011, 02:30 AM   #1465
Default One-Way Woes - Help Needed
I desperately need help / advice.
Over the past 6 months, I have gone thru 5 sets of 2-speed 1-ways.
the problem... when a new set (2-speed adaptor shaft and 1-way bearing) goes into the car, it will run fine for approximately 7 to 8 tanks. Thereafter, it will start to lockup every now and then, i.e. the 2-speed adaptor shaft gets stuck in the 1-way. This is easily resolved by gently turning the 2-speed adaptor shaft clockwise and then it will come out fine. It will come to a stage where the needle pins in the 1-way will dislodge and then I have to change a new set.
I clean and relube my 1-way b4 each outing.
I use a combination of 1-way lube and associated diff grease.
can someone please please please please tell me what i'm doing wrong? The other serpent drivers at my track are puzzled as hell as well.
sammies is offline   Reply With Quote
Old 03-06-2011, 07:05 AM   #1466
nitrodude's Avatar
I never ever ever clean my 2spd oneway, and I only oil everyonce in a while, and I have been running my oneway for 3 years. Im still on my original 960 oneway, there was a point when I used to run every weekend. Just dont clean it, I've seen people that clean and right after they do it goes bad, other brands too. Try it, get a new one, with a new adapter and dont clean it, just run it, I bet it will last.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-06-2011, 08:12 AM   #1467
+1
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
Old 03-06-2011, 08:29 AM   #1468
Also don't mix the lube with the grease. Only use one or the other. Just use the Associated grease.
Old 03-06-2011, 08:50 AM   #1469
sounds like either there is too much play or something is binding. make sure everything is seated properly and there is minimal play
Ghett0 is offline   Reply With Quote
Old 03-06-2011, 11:16 AM   #1470
quietstorm76's Avatar
The oneway from the 950 and 960 are different from the new oneways. If the inside of the oneway is RED, use grease NOT oil. I went thru a couple before I was told.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
