Old 03-01-2011, 07:47 PM   #1441
quietstorm76's Avatar
Originally Posted by kavajas View Post
Hi there,
You used it between the fly pins? And attach 2 little screws in ?
And the gap?
Regards,
Flyweights pivot on the pins in leading configuration. No screws gap .5-.6mm
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 03-02-2011, 11:58 AM   #1442
2CARTEAM's Avatar
Originally Posted by gearhead_22 View Post
Paolo Moprganti takes the win in a 966! Walter Diaz takes the win in Sedan with a 733 (the only 733 in the main) in the KO Grand Prix!
Serpent went 1st with Paolo & 2nd with Christian Lopez in 1/8th expert. Good weekend.
RC Target, Capricorn, Tesla, Ko Propo, Ulti tires.
2CARTEAM is offline   Reply With Quote
Old 03-02-2011, 01:12 PM   #1443
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
snakes showing no mercy this year
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 03-02-2011, 04:23 PM   #1444
Sorry, donīt understand it, if i put it like the original set, one hole inside the flywheel with the shorter ones like Salven says on youtube, and give a 0.6 gap i will melt completely the clutch. That gap is too much for the small ones or iīm putting it in the wrong position. That pins that you refer is there a reference for that?
Thanxs.
kavajas is offline   Reply With Quote
Old 03-02-2011, 04:34 PM   #1445
Thanxs.
The pins on the flywheel. I build my clutch exactly like Salven does. Lets start over. What's the problem with the clutch again?
Does your clutch slip?
Are you looking acceleration?
Primary Weapon: ?
Secondary Weapon: ?
Old 03-02-2011, 05:11 PM   #1446
Thanks for your time and patience,
I used the original spring and a put it at 0.8 tight, rest like Salven says 0.6 gap and the clutch melt, the small ones were smashed between the flywheel and the prate, like it as to mutch gap.
Thxs.
Old 03-02-2011, 05:42 PM   #1447
Thxs.
Double check your gap then because that's a sure sign of too much gap. Make sure you don't have to much play in the clutch bell.
Primary Weapon: ?
Secondary Weapon: ?
Old 03-03-2011, 01:54 PM   #1448
Ok, i will give i try will start with 0.4 gap end play 0.1.
I think a .6 is to much , but thats my opinion, what pins you apply at the second hole?
Thxs,
Old 03-03-2011, 02:31 PM   #1449
M7H
M7H's Avatar
Thxs,
You have these flyweights?
then the right hole of each flyweight is to be put over the pins, the left hole is for an optional little screw you can put in, to give the flyweight some extra weight. Which in turn might give you a bit more punch.
Serpent
M7H is offline   Reply With Quote
Old 03-03-2011, 02:39 PM   #1450
Thank you, that was the picture and the explanation that i need to see, can you please tell me what clutch setup work better? with that flyweight?
I believe my mistake was the wrong hole on the pins.
Thxs,
Old 03-03-2011, 04:18 PM   #1451
M7H
M7H's Avatar
Thxs,
Gap 0.7mm, end play, 0.1mm (I just keep adding 0.1mm shims, until the bell starts binding when tightening the screw, then I remove 1 shim)
With the big alu plate, you can even go to a gap of 1mm, without losing the flyweights. With the older type of plates, 0.8mm became dangerous...
Serpent
Old 03-03-2011, 05:25 PM   #1452
So, the starting point of the spring is around 0.8?
http://www.youtube.com/watch?v=7wjogF57xpo
On this video you can see he tells you to used the left hole on the flywheel, on this way i melted the clutch.
Thxs.
Old 03-03-2011, 05:40 PM   #1453
nitrodude's Avatar
Thxs.
Do you know how to measure the gap? M7H never mentioned the spring in his post.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-03-2011, 05:52 PM   #1454
Dont get me wrong mate but i know what you mean and i dont consider my self o nooby on that matter. Basically is the same way on that video.
M7H tell me to put on the right hole the flywheel pin and on the way i try it, i put it like in the video, on the left pin that sounds more logical, but this flywheels were made at the beginning to put between the flywheel pins, and it melted, used on the left hole on flywheel pin, 0.6 gap .1 end play and .8 spring.(kit spring)
Thxs,
Old 03-04-2011, 02:25 AM   #1455
M7H
M7H's Avatar
Thxs,
The video is correct, I don't know what you mean with left and right hole, we are confusing each other.
These are the holes which must be placed over the pins.
These flyweights where never meant to be put in between the pins, who told you that?
The 10mm tip on 2.40 min in the video, is a good one, as a starting point.
But this is completely depending on the engine used (they can differ up to 1mm in crankshaft length), and eventually can be changed with shims put between front engine bearing and conus.
What do you mean?
Serpent
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 01:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 11:36 PM
SEO by vBSEO 3.5.0
