Serpent 966
#1397
Could someone give me the size of the bearings used in the front WOS streering blocks seen in the link below
http://www.serpent.com/product/903234/
Many thanks.
Many thanks.
#1398
Many thanks.
Many thanks.
#1399
Many thanks.
Many thanks.
#1401
Does anyone run the alu belt pulleys such as the option ones available from Serpent or the CSO Racing ones? If so which ones do you run and what advantage do they have over the standard nylon ones?
Regards.
Regards.
#1402
Smoother drivetrain, Personally i run all of them........the nylon is injection molded so there high/low spots, the alu. ones is machined so it should be perfectly round. Plus I think the grime form the track doesnt collect as easy onto the pulleys
#1404
Am I correct in saying that Serpent do not make alu replacements for all of the pulleys, such as the ones on the front and rear axles?
It would be nice to have all of them in alu.
#1405
http://www.kamikazetoysandhobbies.com/home.htm
#1407
Thanks for the info. Still strange why Serpent does not make them all. Maybe they think they are not required.
Also, what is the difference between these uprights
http://www.serpent.com/product/903257/
and these
http://www.serpent.com/product/903351/optionals/
they both fit the 960/966.
and these
#1409
Is it true that the front alu body posts are discontinued? I find this hard to believe. If so are there any alternatives?
#1410
aluminum body post
http://winnerscirclerc.com/advanced_...6c28dd&x=0&y=0
Lee
