Old 12-26-2010, 05:45 AM   #1381
Winner's Circle's Avatar
Originally Posted by quietstorm76 View Post
Do any Mugen belts fit the 966? I just found a bag of MRX4 belts and wondered if any can be used before I get rid of them.
I always ran a Mugen rear belt as a front belt on my Serpent 960 due to it being the same length but wider. I had aluminum pulleys for both front belt positions and they were wide enough so that the extra width was not a problem.
I think I got longer belt life due to the added width.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 12-26-2010, 08:56 AM   #1382
quietstorm76's Avatar
Hey Lee, how are you? I have 4 front belts and 2 rear. I'm just gonna see if they fit. I have to change all the belts anyway.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 12-26-2010, 10:04 AM   #1383
I am doing great. Thanks for asking. How is that baby?
When I used the Mugen rear belt in front with plastic pulleys the belt was slightly too wide. When I first tried this I would trim the edge of the belt with an exacto knife but I later found that this was unnecessary because after 1 tank of fuel an untrimmed belt would wear the edges off so that the 9mm belt was about 8mm and it now fit perfectly.
Give it a try. I think you will find that the belt will last longer than the 6mm belt that it was designed to use.
Lee
Lee Muse
Old 12-26-2010, 12:15 PM   #1384
Lee
Good advice. I'll do that. I can at least use the belts while breaking in motors and practice.
Primary Weapon: ?
Secondary Weapon: ?
Old 01-02-2011, 08:13 PM   #1385
NitroWD's Avatar
Default Tire wear
my car handling/setup is to my liking but there's a problem with my rear tire wear. it's wearing too fast.
i started with a front and rear 35shore 7mm split but after about 20-25mins, the split is only about 3mm left, what could i do to reduce the rear wear? or maybe increase front wear?
most easy way is to use a harder rear tire shore or softer front shore?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 01-05-2011, 12:45 AM   #1386
Default Caster and Front Wheelbase
Hi,
When making adjustments to caster on the front top axle, do i have to make corresponding changes to front wheelbase as well?
I played around with caster during my last session... i put 5mm caster clips in the front of top axle, but left wheelbase untoched... my front tire wear was funny... the wear was not even from inside to out. it was a little conical... the outside of the wheel had a larger diameter and this decreased going towards the inside of the wheel, but at the last 1mm or so to the inside, the diameter increased...
not sure if you guys can picture what i'm trying to describe...
in any case, any insight / comments / feedback welcome.
thanks
sam
sammies is offline   Reply With Quote
Old 01-05-2011, 05:00 AM   #1387
M7H
M7H's Avatar
Originally Posted by sammies View Post
Hi,
When making adjustments to caster on the front top axle, do i have to make corresponding changes to front wheelbase as well? I played around with caster during my last session... i put 5mm caster clips in the front of top axle, but left wheelbase untoched... my front tire wear was funny... the wear was not even from inside to out. it was a little conical... the outside of the wheel had a larger diameter and this decreased going towards the inside of the wheel, but at the last 1mm or so to the inside, the diameter increased...
thanks
sam
I know what you mean.
The inside wheel should wear like that, straight or maybe a little conical to the inside and with this small "flap"
Caster and wheelbase you should thread independent.
If your car needs more turn, shorten the wheelbase, if it's nervous, enlarge it.
Serpent
M7H is offline   Reply With Quote
Old 01-05-2011, 07:40 AM   #1388
Most drivers in the USA use a softer shore front tire. 35R with a 32F for example. The rears still wear out more so you might go from a 7mm split to a 5mm. Some people have tried 37R with 32F to get more even wear but most stay with one shore softer.
Desoto Racing
Novarossi America, Serpent America, TOP Engines, Matrix Racing Tires, ProCircuit, Titan/Blitz Products, Xceed Products, KO Propo, Enneti, ArrowMax
info@desotoracing.com, www.serpentamerica.com
jdesoto is offline   Reply With Quote
Old 01-05-2011, 05:45 PM   #1389
NitroWD's Avatar
thinking of doing that to try how will my current setup be affected...
Old 01-05-2011, 10:52 PM   #1390
Suspended
yea true, sick bro
GioRacer96 is offline   Reply With Quote
Old 01-08-2011, 05:31 AM   #1391
NitroWD's Avatar
Default middle axle pulley
hi,
just wondering what's the effect if we're to use 24T for the middle axle pulley instead of the 25T?
under what situations and when do we want to use the 24T?
Old 01-12-2011, 02:21 PM   #1392
Hi Guys
Looking at various setup's listed on Serpent's web page I have noticed that the 966 is prefered to be used with thicker shock oil than the 960. What is the reason for this?
I have no knowledge on the 966 as I am still running a 960-08 that I run with an almost default set-up.
Regards.
JIM1 is offline   Reply With Quote
Old 01-12-2011, 02:34 PM   #1393
nitrodude's Avatar
Originally Posted by JIM1 View Post
Hi Guys
Regards.
I havent looked at the setups on the site, but you also need to look at the shock piston they're using. Some drivers will use thicker oil with more holes and other will use thiner oil with less holes.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 01-12-2011, 06:08 PM   #1394
speaking of shock pistons... how do you tell what # hole the setup sheet suggests?
the picture showing the shock piston has 4 holes. If one of the holes is "blacked out", does that mean a 3-hole or 1-hole piston is being used?
Sam
Old 01-12-2011, 06:15 PM   #1395
it means 3 hole is being used.
yappy is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 01:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 11:36 PM
SEO by vBSEO 3.5.0
