Serpent 966
#1306
Hi,
Still fairly new to 1/8 nitro... hoping to get some insight to the dozens of questions that I have buzzing in my head after each 1/8 run.
The shims located at the front CVs... i believe in slaven's video, he mentioned that he gets more turn-in if he placed all the shims on the outside. Looking for some kind sould to explain to me why this would be so. Wouldnt placing all the shims on the outside increase front track-width and thus make the car less reactive to steering response?
Sam
Sam
#1307
Hi,
Sam
Sam
I cant say why you get more turn-in though, need an expert to explain that.
Oh, and just ask the questions, somebody will always answer.
#1308
Serpent Dominates the Novarossi Challenge @ Homestead
With 8 out of 12 cars in the final, Team Serpent had a great result this past weekend at the Homestead Speedway
DJ Apolaro TQ the event over Paolo Morganti by 1.6 seconds in the 10 minutes Ifmar style qualifier.
The final was super exciting. Dj, Scott and Paolo were neck to neck battling for the victory. After the long one hour main, with was Paolo Morganti who took 1st place with DJ finish in 3rd.
#1309
What starter boxes do you like? Right now I have been using the Mugen box but my pit person does not like. it She says its to hard to locate the car in the right position any sugestions?
#1311
I have a old serpent box do they make 966 mounts for it
#1313
Hi,
Was removing the spur gears after a run today, and found that the 2-speed clutch wouldnt come out of the one-way bearing. I couldnt even turn it.
No choice but to knock it out. Put it back in, and it was like normal... turns (in 1 direction of course) and able to take it back out normally.
any idea why this happened? should i be concerned?
sam
sam
#1314
Are you using the set screw that holds the pin in place? The reason what happened to you happened is the pin gets pushed to one side. I think it is not a big deal, as it happens to me every so often and I have not had a problem. That being said, I try to always use the set screw to avoid this issue. But even with the set screw, sometimes it happens.
Regards,
DJ Apolaro
Regards,
DJ Apolaro
#1315
Regards,
DJ Apolaro
Regards,
DJ Apolaro
yes... i am using the set screw to hold the small pin in place. sorry... but what does the pin have to do with the 2-speed adaptior shaft being stuck in the 1-way bearing?
#1316
Sorry, I mis-understood. I though you were having truble taking the adapter off the shaft. If the one-way is sticking to the adapter than you are not lubing it often enough. If you are using the stock silver one-way, make sure to use the associate ball diff grease for the longest life. One-way oil is not enough.
DJ Apolaro
DJ Apolaro
#1317
1) on the top of the box at the edge of the hole where the starter wheel is, mark where the high point wheel is.
2) take the top off of the box. Invert your car so that it is bottom up and now put the starter box top so that it lays on the bottom of the car.
3) position the starter box top so that the marks from step 1 are positioned right under the engine flywheel.
4) put your locator pins in the correct place so that the lid is held where it needs to be. You may have to be creative with the pins because they may hit a suspension arm so some may have to cut off or short nut and bolt may be needed as a substitute.
After you do this your car will fall into the correct place so that only downward pressure is required to spin the engine.
I hope this helps.
Lee
#1318
DJ Apolaro
DJ Apolaro
from what you wrote, i take it that there are other options to the stock one-way? can you point me in the right direction here?
thanks in advance!!
sam
#1319
w2 rear wide offset
Hi,
why would using w2 hub in rear increase corner entry and more steering as stated in serpent homepage ? Thought wider rear will give you more grip, hence less steering?
thanks
thanks
