Old 09-30-2010, 07:47 PM   #1276
Erock's Avatar
Originally Posted by jpeck View Post
Congrats to Larry Barnett and Eric Jones. 1,2 in HOA series w/966.
Thanks John.
I looked back and Larry won the HOA 31 years ago!
Hobbytown USA, Byron's Fuels, RC America, Clints creations paint, KO ProPo, Kevco racing, Picco engines, Matrix Tires
Erock is offline   Reply With Quote
Old 10-10-2010, 09:05 AM   #1277
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
just finish building my 966 and pretty much satified.
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 10-10-2010, 12:14 PM   #1278
captian's Avatar
Good to hear glad your happy with the build
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 10-10-2010, 07:42 PM   #1279
lpdconcepts's Avatar
Trader Rating: 38 (100%+)
Default Serpent 966
Does anyone make a working rear Diffuser for onroad 8th scale?
lpdconcepts is offline   Reply With Quote
Old 10-10-2010, 10:11 PM   #1280
bobbyblaze's Avatar
do this car with transponder mount or where you mount the transponder?
Old 10-11-2010, 12:19 AM   #1281
keavze's Avatar
Default Radio flex-link
Hi,
anyone who's running the flex-link on their 966, what's the part that's 'circled' in the picture? this part is not included in my package 903354.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 10-11-2010, 02:47 AM   #1282
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by keavze View Post
Hi,
thats the original tank spacer post i believe. 903136 ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-11-2010, 02:54 AM   #1283
jca2000au's Avatar
Trader Rating: 9 (91%+)
http://www.serpent.com/product/903196/
jca2000au is offline   Reply With Quote
Old 10-11-2010, 02:56 AM   #1284
Pattojnr's Avatar
Originally Posted by jca2000au View Post
on the Ball Jay. now just let me fix something up with my Sig....
Serpent - Walter RC
Old 10-11-2010, 03:00 AM   #1285
Pattojnr's Avatar
a little tip when i built my car...... i used a dremmel to remove some of the plastic ridge on my servo holder. just enough to allow a 3mm hex driver to go under the radio plate and servo holder. this allows for easy removal of the ball link for the servo arm from the link. also allows you to use a 2mm on the other side so you can get things nice and tight.
Serpent - Walter RC
Old 10-11-2010, 03:04 AM   #1286
Pattojnr's Avatar
Hi,
Keavze ... are you running Salvens setup with the link system ?
something i tried was at the front, salven used 1mm shim at rear of top front arm and 2mm front. so it is angled. do also try 0 shims on rear, and 2mm at the front. this gave a very good amount of steering, and settled the car into, out of corners, and down the straight. it was just alot better all round.
Serpent - Walter RC
Old 10-11-2010, 06:40 AM   #1287
keavze's Avatar
hey paul, how's the going?
you're running the link system with Salven's setup? the latest one?
i've just installed the link system, will only be trying out this weekend.
i'll run with my setup before the 'link' fitted and see how it goes and then maybe make some changes if it ain't good.
what's your front wheel hubs setup? 1 on left with eccentric 'high'?
Old 10-11-2010, 06:45 AM   #1288
keavze's Avatar
i've found out that it's actually a rubber thingy.
http://www.serpent.com/product/1070
Old 10-11-2010, 07:02 AM   #1289
Pattojnr's Avatar
hubs are changed to follow the setup, and mine are low axle setting. if your goign to try the setup, you need to follow it 100%, then make changes from there. it took alot of time mid Nats to change it, but it was well worth it, specially after some minor changes i did my self. i ended up with 45 deg front bar, and the angled top arms as i said. it was just fantastic.
Serpent - Walter RC
Old 10-11-2010, 12:15 PM   #1290
bobbyblaze's Avatar
thanks for the replys .....i notice i used the dremmel alot building the car but what funny my spurs gears didn't have the holes drilled out
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
