Old 07-02-2010, 06:08 AM   #1111
Default Link System
Hi Serpent drivers,
It seems that the pros are using the link system and getting the results.I just got my set and interested to know how to like really assemble it.Yes,the instructions are given but I believe theres some top deck screws arent needed anymore.So need help!!with pics please?
Thanks!!
tq23 is offline   Reply With Quote
Old 07-02-2010, 07:22 AM   #1112
Default Link system
Originally Posted by tq23 View Post
Hi Serpent drivers,
Thanks!!
Tq - you are correct, for the link system you do not use the two M4 flatheads that formerly held the radio tray to the center bulkhead. With everything assembled if you hold the ends of the chassis and twist you'll be able to detect a little movement between the holes where the flatheads used to install. This is not something used on all tracks just another tuning tool in the arsenal to allow us to find the best setup for a track.
Empire Racing - Serpent - K.O. Propo Electronics - Tornado Fuel
Time for us all to grow up and sign our real names on posts.
Rick Davis is offline   Reply With Quote
Old 07-07-2010, 10:23 AM   #1113
Default clutch wobble
hope someone can help me out
My clutch started slipping during my last outing. The only change i made was to tighten the clutch spring slightly as I wanted a higher bite point.
Upon examination... with the whole assembly intact... i notice that the clutch bell (with the 2 pinions) has a slight wobble. The large and small bearings are still good... the cause of the wobble seems to be coming from the top of the housing, where the screw inserts thru the thrust bearing pieces.
I dont remember the whole assembly to have such a 'wobble'.
Can anyone comment whether this is normal?
sammies is offline   Reply With Quote
Old 07-07-2010, 10:38 AM   #1114
Send a message via Yahoo to motojon
Did u check the thrust bearing, and was the screw loose that hold the bell housing on
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 07-07-2010, 06:12 PM   #1115
gearhead_22's Avatar
Send a message via AIM to gearhead_22
I have a new 35+21 that I brought 3 months ago. I can not finish a race with it, the clutch is gone, turns to dust. I put new fly wheel, new clutch bell, new fly weights. before this motor I have had no problem with the clutch please help anyone anywhere.
serpent 977WC-novarossi-748TQ
serpent S120 LTR-S411 4X-F110 fs2
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter http://rccarworld.com/............ serpent.com
Track director at RCCW.
gearhead_22 is offline   Reply With Quote
Old 07-07-2010, 06:22 PM   #1116
thrust bearin is ok... screw was not loose...
I assume the slight play/wobble is not normal?
Old 07-07-2010, 06:36 PM   #1117
try a little more total gap in the clutch
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
Old 07-07-2010, 07:06 PM   #1118
I have had no problem before I put this motor in and also I run 7 on the gap, I will try 8 and let u know.
Old 07-07-2010, 08:10 PM   #1119
go to .9 also make sure you are not shifting to soon
Old 07-08-2010, 01:42 AM   #1120
M7H
M7H's Avatar
Slight play/wobble is normal, it should be there.
Do you use Yellow clutch shoe?
some where known to turn to dust...
Get the Red one.
Serpent
M7H is offline   Reply With Quote
Old 07-08-2010, 03:52 PM   #1121
M7H
M7H's Avatar
This question came up in the 733 thread, so I'm gone post some pictures about a LiFe battery pack I use in my 966, compared to a standard NiMh pack.
See the attached pictures for details.
Serpent 966-life-pack.jpg   Serpent 966-life-966.jpg   Serpent 966-life-size.jpg   Serpent 966-nimh-size.jpg
Serpent
Old 07-08-2010, 07:25 PM   #1122
keavze's Avatar
Default reply to stefan's life battery in 966 issue
replying to stefan's 966 battery issue in 733 thread:
same issue here but i managed to fit it in. you'll need to mount the LiFe battery as far forward as possible, as the tank sits slightly lower towards the rear. didn't need to raise the tank this way and linkage would clear.
another thing: dont use too much tape on the battery at the rear part.
but if i'm using nimh, the battery will fit nicely with no issues.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 07-13-2010, 09:35 PM   #1123
RevMaxx's Avatar
Send a message via MSN to RevMaxx
what servos do you recommend for 966?
steering & throttle
torque and speed (@ 6.0V)
t-i-a
RevMaxx is offline   Reply With Quote
Old 07-13-2010, 09:39 PM   #1124
steering & throttle
t-i-a
KO 30046 aka PDS-2368
Desoto Racing
Novarossi America, Serpent America, TOP Engines, Matrix Racing Tires, ProCircuit, Titan/Blitz Products, Xceed Products, KO Propo, Enneti, ArrowMax
info@desotoracing.com, www.serpentamerica.com
jdesoto is offline   Reply With Quote
Old 07-14-2010, 01:20 AM   #1125
Default 966 Link System
Once again greetings guys,
Alright,i have already fitted my link system onto my 966.so just wanna make sure,after assembly,is the top deck suppose to move side to side freely or does it need a considerable amount of force to do so?i tried meddling with my top deck and it did need some force to move it.so is it suppose to be like that or shud it move more freely?
Please advise!
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 01:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 11:36 PM
SEO by vBSEO 3.5.0
