Old 05-08-2010, 06:28 AM   #1066
NitroWD's Avatar
great job as usual paul...
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 05-08-2010, 01:13 PM   #1067
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Originally Posted by Pattojnr View Post
Hi guys, just letting you know the 966 (only 2 of 22 cars) both made the A final.
a problem with after market Ceramic bearings, and one retired early.
i managed to hold on to 3rd position in the 30 min final, and the winner was Disqualified for being underweight, that moved me up to 2nd position.
i also drove the 733 into 4th position in the tourer final.
Great cars, and easy to work on.
good job sir . you coming down for the serpent tour .
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 05-08-2010, 07:10 PM   #1068
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i wish i could, but due to work i have to plan my time off. i got back From SA and see the Serpent tour going ahead, and i said DAMN !
Nats for sure.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-08-2010, 07:13 PM   #1069
dj apolaro's Avatar
Great job Patto!!
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-08-2010, 07:26 PM   #1070
Trader Rating: 31 (100%+)
What is the trick to getting the motor installed with the sideplates on? or do you just have to take the trans side plate off?
Scott
1968 Camaro: 1:1, 5.3L LM7, Complete Restoration in Progress
Batteries are for flashlights and starterboxes
sdphilips is offline   Reply With Quote
Old 05-08-2010, 07:56 PM   #1071
Pattojnr's Avatar
Scott
by taking the plate off at the spur gear end, everything just lifts up . is the easiest way , and leaving the engine mount behind as well.
Serpent - Walter RC
Old 05-08-2010, 07:58 PM   #1072
Pattojnr's Avatar
Originally Posted by dj apolaro View Post
Great job Patto!!
DJ Apolaro
Thanks DJ. 2 cars are hard, im just lucky they are Serpents, as they seem to be easy to work on with less time than others.
Serpent - Walter RC
Old 05-08-2010, 09:28 PM   #1073
nitrodude's Avatar
Just loosen the pipe side plate(if you use it), you dont have to take it off, and take the motor screws off. Dont take off the motor mount, its easier to just pull the engine, and you dont have to re-set the mesh. I run a Nova and a Picco and the mesh stays the same with both motors.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-09-2010, 04:49 AM   #1074
keavze's Avatar
like patto, i got to take the spur side plate off in order to remove the engine.
taking the pipe side plate off, my engine still couldnt be taken out as the flywheel would be blocked by the brake disc.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 05-09-2010, 11:47 AM   #1075
That is what i was having a problem with.
Are people running both of the side plate stiffeners? The used car i bought did not have either one with it.
Scott
Old 05-09-2010, 11:58 AM   #1076
Default clutch help
Hiya,
Could anyone help me with set up of the clutch ? using
leading flyweight no setscrew
1.8mm spring set to 1.2mm
gap 0.6mm
0.1 end play
iclutch engage slow but ok when warm up..punch get worse after a while and yellow clutch dust seen around in box...clutch very worn and clutch housing very warm to touch.
more or less default setting...read but cant find method of building clutch similar to mugen with flyweight between pins....
xtreme888 is offline   Reply With Quote
Old 05-09-2010, 11:59 AM   #1077
Send a message via Yahoo to motojon
Dito everyone the belt side stiffner just has to be loosened and the motor will slide out
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 05-09-2010, 12:33 PM   #1078
Team Kamikaze's Avatar
Originally Posted by xtreme888 View Post
Hiya,
gap 0.6mm
0.1 end play
1.2mm is too much, try 9.25mm to 9.75mm on the clutch nut using 1.8 hard spring (part # 909520)
set the gap at 0.7mm to 0.8mm
with 3 x 3 set screws on the leading weights
end play set to as long as the clutch shoe does not touch the clutch bell.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-09-2010, 01:25 PM   #1079
Insane rc's Avatar
I agree with kamikaze the 1.8 mm spring works good only i use the white clutch shoe and 0.9 -1.0mm gap and no grub screws.
This setup works best in high grip conditions.
Serpent 966 -Novarossi engines
Insane rc is offline   Reply With Quote
Old 05-09-2010, 02:19 PM   #1080
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Who makes the white clutch shoe?
J.Gonzalez is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
