Old 03-28-2010, 10:36 AM   #1036
Send a message via Yahoo to motojon
Originally Posted by Winner's Circle View Post
Check the ROAR rule book.
There is NO mention of a rule against a solid front axle in 1/8 scale on-road.
Lee
and the point
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 03-28-2010, 11:34 AM   #1037
Winner's Circle's Avatar
Originally Posted by motojon View Post
Alright then.......it caused a serious push everywhere
The solid front axle on a 1/8 car does the same thing that it does on a 200mm car. It makes the car easier to drive fast and much easier to stop. The only time it will push is when you are braking in a turn. If you brake while in a turn with a one way you spin - if you brake in a turn with a solid from axle you will push.
I found the best way to handle driving with a solid front is to brake late and brake hard. Then drive the car though the turn with light throttle and the car follows where the front tires are pointed. My fastest laps were with a locked front.
The drawback to the locked front is the front belt takes a beating due to it having to apply front brakes in addition to pulling the front tires. The fix for this (Serpent car) is the put a Mugen rear belt in place of the Serpent front belt. In order to do this I - 1) put aluminum pulleys on the car that were almost 9mm wide to accommodate the belt and 2) I made a front belt tensioner that was positioned on the radio tray pushing the belt down so that it was causing it wrap around the 16T pulley more to increase the number of teeth that were engaged with the belt. This combination resulted in very good front belt life.
This combination allowed me to pick up 2 to 3 car lengths at the end of the straight by out braking one way cars.
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is online now   Reply With Quote
Old 03-28-2010, 12:21 PM   #1038
Android's Avatar
Lee
If using a front solid axle is truly going to be faster then that would have been the standard for current 8th scale on road cars, obviously it is not true, if not then top drivers like Collari, Bertin, Salven would have adapted the idea!
Android is offline   Reply With Quote
Old 03-28-2010, 01:16 PM   #1039
I said it was faster for ME!
Lee
Lee Muse
Old 03-28-2010, 01:32 PM   #1040
Default front belt tensioner
Here is a picture of the front belt tensioner. Something like this will extend front belt life with a one way or solid front axle.
Lee
Lee Muse
Old 03-29-2010, 12:00 AM   #1041
Hi Guys,
About 15 years ago all mayor serpent drivers had a solid axle at the front (depending on the track). At that time it was with the Serpent Excel. It really worked well on large tracks, where lots of braking was needed at the end of a long strait and without chicanes. A big problem was the wear on everything.
BELCO is offline   Reply With Quote
Old 03-30-2010, 12:34 AM   #1042
Default help
when u are adjusting the 2 speed clutch shoe do u move it by 1/2 turn or 1/4 turn ?
crosten is offline   Reply With Quote
Old 03-30-2010, 12:45 AM   #1043
I always turn 1/4th a time.
Old 03-30-2010, 06:35 AM   #1044
keavze's Avatar
i adjust 1/8 turn when it's really close to where i want...
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 04-08-2010, 06:12 PM   #1045
Default 966
what is the max height of the rear wing on the 1/8 car?
jjrctech is offline   Reply With Quote
Old 04-14-2010, 05:59 AM   #1046
RC MARKET's Avatar
966 link radiotray set
RC MARKET is offline   Reply With Quote
Old 04-14-2010, 07:07 AM   #1047
Send a message via MSN to PMSorber
Under what rules? EFRA or IFMAR?
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 04-14-2010, 04:13 PM   #1048
chuckj's Avatar
Trader Rating: 2 (75%+)
Default SERPENT 966 BRAND NEW IN BOX
BRAND NEW IN BOX SERPENT 966 ON EBAY FOR SALE FOR
500.00 OR BEST OFFER OF AT LEAST 450.00
eBAY SLLER NAME JAMIG624
chuckj is offline   Reply With Quote
Old 04-15-2010, 07:50 AM   #1049
Trader Rating: 30 (100%+)
Darn, I should have been at home surfing instead of golfing! Missed it!
Scott
1968 Camaro: 1:1, 5.3L LM7, Complete Restoration in Progress
Batteries are for flashlights and starterboxes
sdphilips is offline   Reply With Quote
Old 04-20-2010, 10:06 AM   #1050
KostaG's Avatar
Trader Rating: 48 (100%+)
Scott
I was the lucky one!!!
Current Cars:
- Schumacher SX3 & Cougar SV
- Mugen MRX5 WC, Serpent 966e (4s)& Motonica P81e (6s)
Collector/Vintage Cars:
-Serpent F180 (2x), Serpent Veteq, Losi Jrx2, Tamiya Avante & Associated RC10
KostaG is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
