Old 03-14-2010, 04:51 AM   #991
Pattojnr's Avatar
Trader Rating: 19 (100%+)
i use LI Fe battery, no reg needed. gas cooler, i fit near the exhaust, i stand my throttle servo up, so the holes for the reciever on the other side, i put my cooler there. i dont use a switch , just plug the battery straight in to the reciever, or put a short extension from reciever to the outside, and plug in the battery there.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-14-2010, 05:33 AM   #992
LOW ET's Avatar
Trader Rating: 95 (100%+)
which life pack are you using?
LOW ET is offline   Reply With Quote
Old 03-14-2010, 06:21 AM   #993
Pattojnr's Avatar
intellect 1450 mah.
http://www.rc-mushroom.com/product_i...ducts_id=18240
hope this helps
Serpent - Walter RC
Old 03-14-2010, 07:44 AM   #994
LOW ET's Avatar
i have a new xceed lipo and regulator for sale that will fit the 966. look here, FS: ice, lipo, regulator
Old 03-14-2010, 05:49 PM   #995
keavze's Avatar
i'm using the same LiFe battery, however you'll find that the tank will sit slightly higher at the rear side.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 03-14-2010, 05:59 PM   #996
keavze's Avatar
Originally Posted by Pattojnr View Post
did you find an answer to this ? i have ended up getting new drive shafts and axles to fix my car for coming state titles. but the ones i pull out, i can replace just the pins, if you found the part number out ? Cheers. Patto.....
i found that the front drive shaft pins and rear dog bone pins are of different sizes. i've replaced my rear pins and when i tried using the pins for the front, it'll be loose.
Old 03-14-2010, 06:11 PM   #997
Erock's Avatar
Do most of you guys stick with 1500 and 2000 cst oils or do you run regular silicone oils. Or lower CST oils....
I am used to running 40wt - 60wt losi oils. This CST thing for me is like learing a new language..LOL
Thanks for the help.
Hobbytown USA, Byron's Fuels, RC America, Clints creations paint, KO ProPo, Kevco racing, Picco engines, Matrix Tires
Erock is offline   Reply With Quote
Old 03-15-2010, 07:51 AM   #998
chicky03's Avatar
Send a message via AIM to chicky03
Just to give you an idea losi 100wt is similar to 1600 cst.
I talked to DJ the other day and he said they have been running the 1500 and 2000 everywhere lately.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 03-15-2010, 08:51 AM   #999
RC MARKET's Avatar
CSO New product
F bulkhead bearing holder
HARDCOATED STEEL CVD SWING SHAFT SET FOR 966
RC MARKET is offline   Reply With Quote
Old 03-15-2010, 12:07 PM   #1000
Erock's Avatar
Sweet. Thats what I wanted to hear. About done with the build.....Cant wait to run it!
Old 03-18-2010, 05:48 PM   #1001
monsterman's Avatar
Send a message via Yahoo to monsterman
Originally Posted by sdphilips View Post
Yeah, myself, i have a Excel that i got off ebay a couple of years ago. That was the first model of Serpent that i ever raced, so it has specail meaning to me.
Scott
Here's some pictures guys, hopefully you experts can tell me what I snagged up! I quickly found that no one here is running 1/8 on road so this one might be up for sale..
Chris
monsterman is offline   Reply With Quote
Old 03-18-2010, 07:03 PM   #1002
SMcpot's Avatar
Trader Rating: 22 (100%+)
That's not an Excel...looks like a 6000 series car.
SMcpot is offline   Reply With Quote
Old 03-18-2010, 09:57 PM   #1003
Default serpent 966
was thinking about getting a CAR again, but am not sure which to get 1/8 or 1/10 I use to drive a 1/10 a long time ago and like it , but never was able to try a 1/8 car
which is easier to drive?
jorge858 is offline   Reply With Quote
Old 03-19-2010, 04:38 AM   #1004
Winner's Circle's Avatar
Default Serpent 6000
it is a Serpent 6000. Boy does this car bring back good memories.
This was a very good car. You could put a rear differential in it or run it with a straight axle rear end. It was tough but the arms would get soft when the weather was really hot.
The last time I ran one was at the Snowball Rally in Nashville, TN (many many years ago). A weather front came though and the temperature dropped into the high 30s and it was brutal. Hight winds and very cold conditions. Due to the cold, the BMT cars would essentially explode when they touched the wall but not the 6000. I had mine set-up with a read diff and it was the way to go with the cold weather and fine salty silt from a big pile of salt stored near-by.
This was the last great race that the Nashville Club had. I think that they had 80 entries and I was fortunate enough to win the race.
Great memories - great car!
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 03-19-2010, 08:45 AM   #1005
Solara's Avatar
Trader Rating: 16 (100%+)
If you do have someone helped you out to get the 1/8th car all setup, and if you do have a 1/8th size race track well prep for racing...1/8th is actually pretty easy to drive, but NOT easy to get fast. Also, due to the speed of the .21 engine and the car, 1/8th is NOT that forgiving. If you do made mistake, alot of time they are quite expensive to replace.
TC is alittle bit easier to handle even without other's help. And you can race that even with parking lot track. And they usually don't break as bad as 1/8th due to the size and speed because you might be running on a smaller track.
1/8th is like 2X the $$$ on 1/10th....in my opinion only. However, both 733 and 966 are top notch racing machine for sure. So does the brand SERPENT.
SPEED PASSION - King Golden, Speed Passion USA, Speed Power, Hirosaka Pro Products, East Coast Bodies, Awesomatix USA, Roche USA, Schumacher Racing, Hurricane Motorsports, Serpent America, Sweep Racing USA. http://www.spautomobile.com/en/index.asp (SPEED PASSION AUTOMOTIVE)
NEW Speed Power/Speed Passion direct sale site - http://shop.speedpowerrc.com/
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
