Old 11-18-2009, 04:00 AM   #856
Kodak Hodak's Avatar
Send a message via MSN to Kodak Hodak Send a message via Yahoo to Kodak Hodak Send a message via Skype™ to Kodak Hodak
Also you could tighten that nut for flywheel down a bit more, had similar issues with mugen and just more man power was required to get that needed length!
★ DORMANT RC RACER ★
Kodak Hodak is offline   Reply With Quote
Old 11-18-2009, 05:24 AM   #857
keavze's Avatar
try a longer retainer?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 11-18-2009, 01:30 PM   #858
Nitro Norway's Avatar
Hello. I have added shims on the retainer that fits inside the outer clutch bearing.This gave clearence to adjust clutch gap,Thank you for this greate idea!
keavze use your longer retainer on your wife lol!
-Serpent 747-
-Sanwa m11x.
-RBM3.
-LÝrenskog modellbilklubb.
Nitro Norway is offline   Reply With Quote
Old 11-18-2009, 11:28 PM   #859
royco's Avatar
can any one tell me whats the diff between os1 and os2 also what does TQ mean
royco is offline   Reply With Quote
Old 11-19-2009, 03:43 AM   #860
Winner's Circle's Avatar
OS1 means Serpent style wheels and OS2 means Kyosho/Mugen style wheels. Because these wheels have different offsets, you are required to change some parts in order to use one type of wheel or the other.
The early 960 cars came out with OS1. Then for a short time the kits came with the parts so that you could build it with either OS1 or OS2. Later 960 and 966 kits came as OS2 kits.
There was a lot of speculation about which offset gave the quickest lap times. Because Serpent finally changed to OS2 I assume that is the OS2 must be the quicker off-set.
TQ = Top Qualifier
Lee
Lee Muse
leemuse3445@comcast.net
Kyosho ST-RR, Kyosho MP9, Murnan Modified Engines
Winner's Circle is offline   Reply With Quote
Old 11-19-2009, 06:16 AM   #861
royco's Avatar
Thanks for the reply Lee
Old 11-20-2009, 08:16 AM   #862
SERPENT7twenty's Avatar
Trader Rating: 20 (100%+)
Hi guys. I want to true some tires for set-up only purposes .. what diameter should I true them down to to set ride hit? From what I've been told I should true them down to the smallest diameter ... any help would be greatly appreciated, thanks!
TEAM KAMIKAZE - SERPENT 966 - NOVAROSSI - HUDY - KO PROPO - XCEED
Kamikaze Development Driver - R&D = Rebuild & Destroy
www.Kamikazetoysandhobbies.com
SERPENT7twenty is offline   Reply With Quote
Old 11-20-2009, 09:01 AM   #863
use the size that you would run a qualifier
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
Old 11-20-2009, 09:06 AM   #864
Team Kamikaze's Avatar
8mm front and 9mm rear with the Hudy set up station installed on the car, this way it will stay consistent whether you are running with a big tires or small tires.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-20-2009, 09:31 AM   #865
Thanks fella's!
Old 11-22-2009, 04:03 AM   #866
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Default xceed zytec
hey guys have a painted stickered & fit zytec for sale
body has supports in it and wing 60$ shipped
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 11-26-2009, 07:04 AM   #867
royco's Avatar
more of my 966
Serpent 966-ca3b0031.jpg   Serpent 966-ca3b0032.jpg   Serpent 966-ca3b0033.jpg   Serpent 966-ca3b0034.jpg   Serpent 966-ca3b0035.jpg
Roy
Serpent 966,Maxpower XL9 TQ and XL7, Futaba 4pk
Old 11-26-2009, 07:08 AM   #868
royco's Avatar
Serpent 966-ca3b0036.jpg   Serpent 966-ca3b0039.jpg   Serpent 966-ca3b0037.jpg   Serpent 966-ca3b0040.jpg   Serpent 966-ca3b0041.jpg
Roy
Old 11-26-2009, 07:09 AM   #869
royco's Avatar
Roy
Old 11-26-2009, 08:06 AM   #870
^^^^^^^^^NIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIICE Roy
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
