Old 10-26-2009, 07:24 PM   #826
keavze's Avatar
Originally Posted by Brian Bosley View Post
It puts 70 grams in the center, bottom of the car. this is the absolute best place to put weight because the car pivots around this axis side to side and lowers the COG at the same time.
Unfortunately my weak scale only goes to 2000grams so I don't know if my car is overweight or not and I am not really big on running lipo.
so it aids in having more steering?
when do we need to use it?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 10-27-2009, 07:59 AM   #827
Send a message via Yahoo to motojon
It aids in making weight if your running Lipo, as there is a 60g-70g difference in running nicd,nimh compared to lipo
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 10-28-2009, 02:49 AM   #828
NitroWD's Avatar
so if i'm running nimh then i should be using the carbon plate instead?
btw what's the minimum legal weight for 1/8?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 10-28-2009, 07:05 AM   #829
2525 grams, and my scale does exactly 2000....... so I can't tell you what the stock car weights but my new scales will be here soon and I can set corner weights and they go to 6000. check out gram-scales.net (maybe .com) and they have a ton in the $20-30 range. you really shouldn't be without 1 scale, when the xray touring car came out, I was able to weigh the drivetrain which was claimed to be the lightest on the market and got my kyosho cars to match by using older kyosho parts (more plastic, less aluminum mostly)
Support those that support us
http://ActivRC.com http://TeamPowersUSA.net http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 10-28-2009, 08:00 AM   #830
Pattojnr's Avatar
Trader Rating: 19 (100%+)
when using lipo my 966 was underweight. i had to add 55grams of stick on weight. by using the 70 gram brass holder, it adds teh weight to the most central and lowest possible area. even though it made it 15 grams or so over, didnt bother me cause it cant fall off in an incident.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-28-2009, 10:03 AM   #831
NitroWD's Avatar
Default weight
woah, i just weighed my 966 (race ready with the brass plate and nimh), it's at 2656g!
time to ditch the brass and use the carbon instead. it would be about 2590g.
if i use LiFe battery i would cut another 30+g.
Old 10-28-2009, 10:23 AM   #832
The Brass try is for Lipo but also try weighing it with the smallest tires you will have after a run, empty tank, thats when they weigh you is after a qual/main, so you need to make sure it weighs the minimum at that point
My Gpa(RIP)
Old 11-01-2009, 08:10 AM   #833
I got my scales and weighed the car and found I was in the 2585 area except I had to install the 50g weight on the right side to corner balance the car (light electronics I guess) so I am pretty far over.
I'm going to see what titanium screws and other bits will do but I am not sure how to get 100+g off this car although I did weigh it with 74 and 67mm tires.
Old 11-02-2009, 06:32 AM   #834
keavze's Avatar
my 966 with KO full size servos and LiFe battery weighs 2558g.
if i used half size servos, it'll be about ideal supposingly.
i'm not so concerned with my 966 weight but more worried about my 733 weight; needs to reduce about 60g more!
Old 11-16-2009, 11:25 AM   #835
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Help!
I picked up the optional soft antiroll blade part 803204.
Although they have a different part number than the ones included in the kit they apper to be the same thickness in the middle,same width in the middle when measured with digital calipers. Only a slighty different color.
Can anyone tell me if they are in fact any different or just a part number mix up in the instruction manual?
That also being said anyone have a suggestion on a softer front sway bar? Perhaps from a different kit that will fit?
J.Gonzalez is offline   Reply With Quote
Old 11-16-2009, 12:45 PM   #836
nitrodude's Avatar
Originally Posted by senna555 View Post
Help!
Get rid of the front swaybar, put green springs in the front and red or pink in the back, you're gonna get all the steering you need. Use the rear bar to dial more/less steering.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 11-16-2009, 01:06 PM   #837
M7H
M7H's Avatar
That would be the fast solution..
You can also with your next body move it more forward to get more steering....
Serpent
M7H is offline   Reply With Quote
Old 11-16-2009, 02:30 PM   #838
nitrodude's Avatar
Seriously, you should try it. Nigel Sim gave me that set up and works great. Just use the rear bar to dial the steering that you need.
Steven Muller
Ronin Speed Parts
Old 11-16-2009, 02:56 PM   #839
M7H
M7H's Avatar
I know...
But still with a "poor" body you might miss some steering....
Serpent
Old 11-16-2009, 03:27 PM   #840
Pattojnr's Avatar
on a low grip track, i use no front bar but i use the grey spring and red rear
Serpent - Walter RC
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 11:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 04:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 01:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-25-2009 12:10 AM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 11:36 PM
SEO by vBSEO 3.5.0
