Old 10-21-2009, 05:17 AM   #811
NitroWD's Avatar
Default adjust rear camber
hi guys,
i just couldn't remember:
to increase rear camber, for the left upper arm i adjust downwards the 'collar' and for right upper arm i adjust upwards the 'collar'? or it's the other way?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 10-21-2009, 05:42 AM   #812
M7H
M7H's Avatar
it depends on how you've put things together....
But, just rotate the collar and you quickly can see if the arm gets shorter or longer.
To increase camber, the upper arm needs to be shortened...
Serpent
M7H is offline   Reply With Quote
Old 10-21-2009, 07:20 AM   #813
Do you guys have a problem with the white pivot ball nuts seizing? Since the build I am about 50/50 on them getting stuck in the housings and I am using a new wrench that appears to fit tightly but it spins. I can freeze the part in my freezer for a few hours but that doesn't work as well at the track.
Support those that support us
http://ActivRC.com http://TeamPowersUSA.net http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 10-21-2009, 12:43 PM   #814
Default 966
I have been running the car since it came out and i have not had this problem.
CharlieJunkins is offline   Reply With Quote
Old 10-21-2009, 01:14 PM   #815
Send a message via Yahoo to motojon
I personally use the glow plug wrench with the hex on one end, it has been working well for me. But also make sure that its not getting cross threaded when installing, im not doubting your mechanical abilities, its just a possibility
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 10-21-2009, 05:49 PM   #816
captian's Avatar
never had that problem !!!! get the hudy tool it works great
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 10-22-2009, 07:24 AM   #817
keavze's Avatar
Default front CV pin size
anyone knows the pin size for the front cv? i'm in the process of replacing the drive pins...
for the rear dogbones, pin size is 3x12 but front cv the 3x12pin is too loose!
where can we get replacement pins for the front cv?
or we simply gottta buy http://www.rc-mushroom.com/product_i...oducts_id=5469 ?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 10-22-2009, 08:11 AM   #818
Doug M's Avatar
I think you want to get Serpent 902282 and Serpent 902283 for your rebuild.
http://www.serpent.com/product/902282
http://www.serpent.com/product/902283
Doug M is offline   Reply With Quote
Old 10-22-2009, 12:23 PM   #819
captian's Avatar
doug that would be the best option
Old 10-22-2009, 05:17 PM   #820
keavze's Avatar
thanks doug but what i really need is the pin at the 'ball' end...the end that's fitted to the 1way drive cup.
Old 10-23-2009, 05:56 AM   #821
captian's Avatar
now you tell us !!!
Old 10-25-2009, 09:29 PM   #822
What are you guys using for batterys and trays? Any idea what the serpent brass tray weighs?
Old 10-25-2009, 09:42 PM   #823
Team Kamikaze's Avatar
Serpent Brass battery weighs 70 grams.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 10-26-2009, 06:32 AM   #824
keavze's Avatar
how will it affect the car?
Old 10-26-2009, 11:05 AM   #825
It puts 70 grams in the center, bottom of the car. this is the absolute best place to put weight because the car pivots around this axis side to side and lowers the COG at the same time.
Unfortunately my weak scale only goes to 2000grams so I don't know if my car is overweight or not and I am not really big on running lipo.
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
