Old 10-13-2009, 12:32 AM   #781
NitroWD's Avatar
Woah...all these are the Minimum parts to have?
Seems a lot to me. I was thinking of belts, gears and arms only...
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 10-13-2009, 12:55 AM   #782
M7H
M7H's Avatar
Probably the part you don't have as spare, will break....
But buying the front and rear "crash sets" Sam mentioned, is not so expensive, because they are sold as a set...
at least 1 spare clutch shoe is smart to have, and a front belt.
Serpent
M7H is offline   Reply With Quote
Old 10-13-2009, 02:24 AM   #783
captian's Avatar
well its a little different from offroad and your going a lot faster and have no dirt to softin the crash
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 10-13-2009, 08:51 AM   #784
I left the off-road stuff after getting tired of all the cleaning and just got back to on-road, although i have not bought the Serpent 966 as of yet i do have the MRX-4X and will be buying the 966 at the end of this month, i know with off-Road you can be slightly off and still win, with on-road it is different. I love what Serpent has done with the crash kit packages, i also fly heli's and have been flying for about 6 years now, this is what Raptor started doing when they got into the heli game selling a crash kit for those times when things did not go so good, it makes life sooooo much easier in the long run with the crash kit, one big hurray for Serpent to do this and it shows that they are always trying to find ways to be innovative in their ways. I cant wait to build my 966, although i am nervous as heck when i start to run these on-roads little monsters, they are fast and furious, i just want to have fun again, by the way this site is sooooo informative that it makes life easier!
Serpent Lover is offline   Reply With Quote
Old 10-13-2009, 10:24 AM   #785
captian's Avatar
well have fun building !!!!! and welcome back
Old 10-16-2009, 02:37 AM   #786
royco's Avatar
hi guys this is my 966
royco is offline   Reply With Quote
Old 10-16-2009, 02:41 AM   #787
royco's Avatar
sorry too big a file
Old 10-16-2009, 06:40 AM   #788
royco's Avatar
Old 10-16-2009, 05:34 PM   #789
captian's Avatar
Originally Posted by royco View Post
very nice all ready to burn some tarmac and burn some nitro
Old 10-17-2009, 04:14 PM   #790
Charles Godwin's Avatar
Right guys n gals. Looking to get down to the track mid week to do some proper testing but i have a few questions (it'll be my first time out on track with the car). I've set the clutch at the standard settings. Now a few questions about it...... Tightening/loosening the clutch spring - what effect will it have on the car? I'm guessing tighter the nut (not to much) the more punch it will have out of the corners as it will have a higher rpm when it engages? But to tight and it won't even engage because it can't 'expand'...?
Clutch gap i've set at standard 0.7mm. Now if i used 0.8mm would it have again more punch and if i used 0.6mm it would be smoother/easier out of the corners?
Now about the end play. I've set the clutch gap etc etc and it says place small shims after the clutch nut and in between the first bearing. Would that effect the clutch gap though? Or do i just carry on shimming it out so it has little end play (just enough)? It's probably got about 0.5mm end play after i set the gap and placed a couple of shims behind the bigger bearing. EDIT - or just a thought, is the end play set so the clutch bell doesn't drag on the clutch shoe??? So more shims behind the bearing would make a dragging clutch bell free and not rub against the clutch shoe????
Now i've adjusted the two speed shoe-gap as the manuel states. I would guess that more of a gap between the 2-speed shoes and the gear drum/bell would result in a later gear shift? How much would yo notice on say quarter of a turn adjustment? Or just use fine adjustment say a 8th of a turn if its sensitive?
I bet you lot get asked these sorts of questions all the time but it would be a very big help.
Couple of other questions . I can set the caster of course using the top spacer on the arms. Question is say if i shorten or lengthen the front wheelbase do i need to do anything on the caster to keep the same degree? Hope you know what i meen...
On the rear suspension arms like the castor. If i shorten/lengthen the rear wheelbase do i need to the same adjustment on the top arm? Or again do i just adjust one thing and leave the other as it is? If so what effect would i see in putting more shims behind (shortening) the top arm?
Now from my 10th electric touring car days, if i raise the outside link on the rear hubs say 0.5mm is that the same as lowering the inside link (giving more rear grip).
Something have no idea about. There are multiple mounting holes on the upper mount. I have it in the standard mount on the hub i have it in the upper hole too. If i were to move the upper body mount to the outside hole would there be a handling change and the same with the hub mounting... if i mounted it in the lower hole would there be a change in handling. Or am i getting to complicated and it's just for mounting the body at the right height (i got a Xceed Zytec).
Rear roll bar and front. Is there a way to adjust the tension of these? I've only ever used actual bars....
If you lot can help me out in any way that'd be great. Just ran me Picco Evo3 Edo in and itching to get on track
Cheers, Chaz
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 10-17-2009, 04:52 PM   #791
M7H
M7H's Avatar
Yes.
Yes.
No, it will not effect the clutch gap.
Indeed carry on shimming until the cluchbell starts binding, then take the last shim out again...
No, the bigger the gap, the more agressive the shifting will be.
You don't want that.
Make the gap as small as possible, like the manual says, the shoes should almost touch the 2nd gear housing.
The shifting point is adjusted with both screws wih the springs around them.
No problem.
Yes, if you shorten the wheelbase by lets say 2mm, you should also move the upper arms 2mm back, to have the same caster angle as before.
Again, you need to make the same adjustment on the upper arms.
On the rear the arms will even start binding if you don't.
If I understand correctly, no.
The settings for the rear upper arms are used for changing "camber rise"
Just play with it, and find out yourself...
The Zytek is best with the rear mounted as high as possible (that's what it is designed for, it is developed on the Serpent car)
You can turn them.
Flat/soft means the most grip, rotated 90 degrees, means least grip.
Very nice engine!
Cheers, Chaz
Cheers, Martin
Serpent
Old 10-17-2009, 05:16 PM   #792
Cheers for your help Martin. Much appreciated .
Chaz
Old 10-17-2009, 07:00 PM   #793
SERPENT7twenty's Avatar
Trader Rating: 20 (100%+)
Talking
Hi guys ... thanks to Sam at Kamikaze I'm the proud new owner of a brand spanking new 966
TEAM KAMIKAZE - SERPENT 966 - NOVAROSSI - HUDY - KO PROPO - XCEED
Kamikaze Development Driver - R&D = Rebuild & Destroy
www.Kamikazetoysandhobbies.com
SERPENT7twenty is offline   Reply With Quote
Old 10-17-2009, 07:00 PM   #794
keavze's Avatar
Default Rear droop limited?
hi guys,
i've just picked up a 966 to join it's little brother 733.
i've found that if the rear bodymount is fitted using the lower hole on the wheel hubs, you can't setup the rear droop at all, seems like the lower hole on the wheel hub could be used only.
if this is the case; what's the usage of the lower hole on the wheel hub then?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 10-17-2009, 07:15 PM   #795
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by keavze View Post
hi guys,
right now i'm setting the car up but when it comes to rear droop, i just can't seems to get the rear arms to lower enough for droop of 7mm even if i've backed out the droop screws totally.
the problem is that the rear body post mount is preventing the rear arms from dropping down as the rear body mount is connected to both left and right arms and also at the center.
am i missing something here?
on the hubs use the top hole for the side brackets, lower hole on the actual bracket its self, and then play with the pin with e clip on the body mount hieght adjusters. i will try to get a pic for you in a minuet. so keep an eye out.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
