Old 07-10-2009, 12:39 AM   #646
cheers for the info toughbeard,muchly appreciated.
burty
burty is offline   Reply With Quote
Old 07-10-2009, 06:25 AM   #647
Nitro Norway's Avatar
Hi! will the kyosho/mugen rim fit the new 966,
-Serpent 747-
-Sanwa m11x.
-RBM3.
-LÝrenskog modellbilklubb.
Nitro Norway is offline   Reply With Quote
Old 07-10-2009, 06:30 AM   #648
Toughbeard's Avatar
I use rims with no cone groove. I believe standard rims fit the 966.
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 07-10-2009, 07:07 AM   #649
Thanks! I'am about to order a 966,do i need any uppgrade parts like orange drivebelts or alu pullys.
-Serpent 747-
-Sanwa m11x.
-RBM3.
Old 07-10-2009, 07:12 AM   #650
M7H
M7H's Avatar
No...
The 966 comes box stock with parts that are only optional with other brands.....
Drivers from the other brands will say there car doesn't need these options, but with the 966 they come stock with the kit, so actually they can not be called optionals...
Serpent
M7H is offline   Reply With Quote
Old 07-10-2009, 07:17 AM   #651
Toughbeard's Avatar
the new kits come with the orange belts. The standard plastic pulleys work fine as long as you keep them clean.
Serdar Aytemiz
Old 07-10-2009, 07:44 AM   #652
Trader Rating: 18 (100%+)
Default Serpent 966
Serpent, Kyosho, Mugen all us the same wheel now.
No need to purchase tires/wheels just for the Serpent anymore
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 07-10-2009, 07:45 AM   #653
gday again guys,sorry to bother you,i just started my build tonight,ive come across a couple of small things im a bit unsure of.first is the screws that hold the steering rods to the ackerman,it says 6mm screws in the manual,but i cant get them to bight on being the screws are to short,tryed longer screws but the thread doesnt go far enough???
second was a bindiing problem,it states in the manual to use 4 shims on the inside of the front axles but it ended up pushing the axles tight into the front oneway,which was causing the binding,i instead used 2 on the inside a 4 on the outside of the hub,this wont be a problem will it???
cheers heaps for the help guys,regards,burty.
Old 07-10-2009, 08:25 AM   #654
M7H
M7H's Avatar
Don't exactly understand what you mean...
But check the Serpent site and look at the pictures...
The steering rods go UNDER the ackerman setting...
It is not a problem, you have now put more offset in the front wheels, you can play with this anyway (yet another option that some other cars don't have), but what you now did is a good starting point anyway, because Kawahara tires will now fit.. and not in the basic set-up...
But, what you can also do is the following.
on page 4 of the manual point A1 there is a plastic shim put on the driveshafts, take that one out, or on page 7 point A10, make the front trackwidth a bit wider, so instead of 2.4 and 1.5mm, add 1 mm, so lets say 3.4 and 2.5mm....
I'm refering to the manual which is on the Serpent site.
http://www.serpent.com/product/903009/downloads/
1 more tip, although not always mentioned in the manual, use blue thread lock on the alu parts (tamiya has a real good one)
If you don't have it yet, then at least use it on the 2 x 3 screws holding the rear main driveshaft, in the manual page 10 point B4, just thight them a little, don't overtight them and use thread lock there.
Because the rear is aluminium, it will be warmed up by the engine, and that way might snap these screws if they are overtightened....
Serpent
Old 07-10-2009, 08:42 AM   #655
Send a message via Yahoo to motojon
Originally Posted by jdev View Post
Are you running the Xceed ones? I just got one and it doesn't seem to have a balancing tap so I was a little concerned since it's a 2S.
yes xceed lipo, i dont worry about the balancing on these
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 07-10-2009, 09:23 AM   #656
awesome info m7h,thanks heaps,in regards to the ackerman,my problem is the length of the screw that holds the steering rods on to the ackerman,the manual says 2 of 6mm screws ,when i go to screw the steering rods on theres bugger all thread showing,i went with a 10mm screw but the thread in the ball that goes into the steering rod end is to short as well.cheers heaps for your help
Old 07-10-2009, 09:34 AM   #657
Team Kamikaze's Avatar
It could be a mix up of the screw, just use a 3 x 8mm button head screw.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 07-10-2009, 09:40 AM   #658
`thanks sam,that was pretty stupid of me wasnt it,lol.2.38am here now and im still building,this is a very nice kit,the quality is amazing.
cheers ,burty
Old 07-10-2009, 06:59 PM   #659
jdev's Avatar
Ok, thanks.
jdev is offline   Reply With Quote
Old 07-11-2009, 03:59 AM   #660
sorry to annoy you guys once again with my stupid questions,but i will,lol.just setting up the 2 speed shoe gap and im not having any gap at all when i put my 2speed shoes into the second gear drum,ive loosened the gap setting screws but i cant get any gapat all,is it alright to give the shoes a light sand on the high spots??or is this a no,no?or am i doing something wrong?sorry,and one more thing,did any of you guys have to trim anything off the bulkhead to get your motor in,mines tight as a nuns.once again guys thank you very much.
regards burty.
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
