Old 07-08-2009, 07:42 AM   #631
M7H
M7H's Avatar
That's what i mean with "2/3"
These packs:
Serpent
M7H is offline   Reply With Quote
Old 07-08-2009, 08:14 AM   #632
Pattojnr's Avatar
Trader Rating: 19 (100%+)
These packs:
thats the pack. seems a small 10 min break, you know, walk away, dont think about it. then get back to it, and move it this way and that way, and presto, it works. ahahaha. very small tolerances, but it doesnt rub, and brass tray fitted. maybe the Angle of the Dangle, and tilt ya head that way seemed to work all good, cheers though. i had many problems with the carbon tray, and novarossi engines, as well as the Engine mount. the Sirio (capricorn) must sit a bit higher up in the carb area.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-08-2009, 08:16 AM   #633
Pattojnr's Avatar
You are running the 2/3 NIMH cells?
The brass battery tray is meant for lipo's...
You could maybe go to "AAA" cells, to be able to lower the tank a bit....
sorry i read it this time the pic took away my ability to read. wasnt hard was it
Serpent - Walter RC
Old 07-08-2009, 12:29 PM   #634
M7H
M7H's Avatar
Well, never mind, you solved the problem.
But isn't it a bit overdone, AND a normal battery, AND a brass tray?...
Serpent
Old 07-08-2009, 04:20 PM   #635
Pattojnr's Avatar
well i can take my 40g of stick on weight off. if im still 30 or 40g its ok. untill the grip comes up on the track, it may just be that little bit better earlier on.
just trying it out, no harm to see how it effects the car. thanks M7H, i can always put the carbon tray back on, not a big job.
Serpent - Walter RC
Old 07-08-2009, 10:56 PM   #636
jdev's Avatar
Any US store get the orange belts in yet? I stripped the front belt on my 966 and was going to pick up a few sets.
jdev is offline   Reply With Quote
Old 07-09-2009, 12:06 AM   #637
Toughbeard's Avatar
how are your tests with lipo reciever packs? any problems with fuel spills etc?
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 07-09-2009, 12:30 PM   #638
Send a message via Yahoo to motojon
None what so ever just make sure to have a regulator
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 07-09-2009, 01:08 PM   #639
trickd122's Avatar
Are you having a problem sourcing parts for this car?
trickd122 is offline   Reply With Quote
Old 07-09-2009, 02:17 PM   #640
serpentamerica's Avatar
Hi Jdev, we are receiving a large shipment early next week and we will deliver to all our dealers. We do have 6361 in stock, which is the front black one. Ask your LHS to order that or contact us thru serpentamerica.com
Enjoy your 966!
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: info@serpentamerica.com
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Old 07-09-2009, 07:12 PM   #641
jdev's Avatar
No, not at all. Just wanted to check out the orange ones if they were available.
Old 07-09-2009, 07:12 PM   #642
jdev's Avatar
Enjoy your 966!
Thanks for the update!
Old 07-09-2009, 07:16 PM   #643
jdev's Avatar
Are you running the Xceed ones? I just got one and it doesn't seem to have a balancing tap so I was a little concerned since it's a 2S.
Old 07-10-2009, 12:06 AM   #644
gday guys,sorry to annoy you once again,silly question for you,i was going to start my build this weekend and i was wondering about the grease im using,ive got kyosho one way bearing grease to use,is this the right stuff,i thought it would actually be more like oil??sorry again for the stupid questions,cheers,
burty.
burty is offline   Reply With Quote
Old 07-10-2009, 12:14 AM   #645
Toughbeard's Avatar
burty.
Oneway bearing oils are very very thin and they will not feel like oil but they will work better than normal oils and will prolong the life of you oneway bearings. make sure to apply oil after each run and you ll be fine.
Serdar Aytemiz
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
