Old 07-06-2009, 03:49 PM   #616
Originally Posted by Storm_PT View Post
Hi. Can anyone tell me how many teeth each belt has in a Serpent 960/966? I know they are S3M, but don't know the teeth number.
Nevermind, it was right there in Serpent's site:
Front:60S3M201
Rear: 80S3M210
Side: 60S3M432
Divide the second number by 3 and you get the teeth.
Storm_PT is offline   Reply With Quote
Old 07-08-2009, 12:37 AM   #617
gday there again guys,was hoping for some more help if i could?
just after some setup info,body setup,tire size and what not,just a good starting point,im just going to use the default setup for now,until i get used to the car,the body im using is a blitz lola r09,also, you guys use the laydown setup for throttle servo?cheers heaps for the help,i cant wait to start on this puppy,looks like a sweet bit of gear,cheers and beers,burty.
sorry one more thing,can one way lube be substitued for anything else,or is it a special lube??sorry for the dumb questions.
burty is offline   Reply With Quote
Old 07-08-2009, 01:49 AM   #618
M7H
M7H's Avatar
The default set-up is a real good starting point.
I actually only drive with more caster, so the front upper suspension arm 2mm more backward then default...
Depending on the track you will be running the car on, and the possible corner speed, always look at how your tires wear and make camber adjustments from there.
The one way lube really is only meant for that, it is so thin, that using it as a lubrication anywhere else to me is useless....
Serpent
M7H is offline   Reply With Quote
Old 07-08-2009, 01:57 AM   #619
Toughbeard's Avatar
for oneway you need a very thin oil or the oneway will heatup from friction. I suggest either a specific oneway lube or gun oil.
depending on your country sometimes its easier to find one then the other.
Places to look.
Hobby stores (duh), Bearing distributers (for brand specific lubes), gun shops
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 07-08-2009, 02:11 AM   #620
M7H
M7H's Avatar
Haha, I totally misunderstood his question about the one way lube Toughbeard....
@Burty, can't really give you info about the body, because I drive the Zytec, but I think if you mount it about 10mm in front of the bumber, it should be ok.
Laydown throttle or not... it depends on what you want.
I don't use the laydown option, but installed my receiver next to it, to be able to change frequency (non spectrum driver)..
I did mount my throttle servo under the radio plate to lower it (can only be done if it fits between radio plate and chassis)
Serpent
Old 07-08-2009, 02:26 AM   #621
Toughbeard's Avatar
And I forgot to comment on the other issues Getting old
Laydown Servo: More work , gets the CG down if your using a heavy servo. I find it more prone to malfuntion. (more parts moving) . protects servo from spills better but lets the servo be attention of heavy damage.
I have a protoform Lola and a blitz body. I have ordered some zytecs as well. blitz is slower but has a lot of traction on the front. Lola is fast but pushes a little so need to reset. Protoform lola has a very long nose I didnt check the measurement but I centered the frnt wheels to the body wheel wells. Seems to work fine for now.
Serdar Aytemiz
Old 07-08-2009, 02:35 AM   #622
thanks heaps for the help guys,your a wealth of knowledge on this forum,i imagine you will be hearing from me again in the not to distant future,cheers heaps.
burty.
Old 07-08-2009, 02:48 AM   #623
M7H
M7H's Avatar
Originally Posted by Toughbeard View Post
Getting old
Same here...
But, recently won an open club / 40+ race here in Holland, which made me feel young again!...
Protoform Lola?
You mean this one:
And the Blitz, is that the same idea, or the newest R09...
Because if not, you will really feel a BIG difference with the Zytec... and once you get used to it and changed the car set-up accordingly, a BIG smile on your face...
I even retired my custom painted centrals (used 2 of them) after trying the "home painted" Zytec...
burty.
Your welcome!
Serpent
Old 07-08-2009, 02:56 AM   #624
Toughbeard's Avatar
Same here...
But, recently won a open club / 40+ race here in Holland, which made me feel young again!...
Yeah I won the Nationals last year in Electric Touring here in Turkey that made me feel young,too. until the next monday
Protoform Lola?
You mean this one:
http://www.m7h.nl/m7h/950R_files/950-9.JPG
yeap I have one of those and this
Serdar Aytemiz
Old 07-08-2009, 03:10 AM   #625
M7H
M7H's Avatar
Well, be ready for some change then....
Serpent
Old 07-08-2009, 06:18 AM   #626
Toughbeard's Avatar
I need to make my own body
Serdar Aytemiz
Old 07-08-2009, 07:08 AM   #627
Pattojnr's Avatar
Trader Rating: 19 (100%+)
guys, i just put in the brass battery holder on my 966, i run a nimh pack, and i cant setup the carb with out hitting the tank now. any suggestions on how to remedy ? i could put 2 extra O rings on the base of the carb, but has anyone got a better idea ? cheers. Patto....
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 07-08-2009, 07:24 AM   #628
M7H
M7H's Avatar
You are running the 2/3 NIMH cells?
The brass battery tray is meant for lipo's...
You could maybe go to "AAA" cells, to be able to lower the tank a bit....
Serpent
Old 07-08-2009, 07:28 AM   #629
Pattojnr's Avatar
na i run the 1600mah pack similar to what guys run in the mugens. i know its higher, but it works with the carbon tray. far as i could see, the brass was close to the same depth, with the recess, it fits in snug, but just a little bit too high.
Serpent - Walter RC
Old 07-08-2009, 07:36 AM   #630
Send a message via Yahoo to motojon
yah brass is for Lipo the carbon is for everything else also if you dont have it, run the balance wheight that hangs off the X brace too
My Gpa(RIP)
motojon is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
