Old 05-02-2009, 09:38 AM   #526
Send a message via Yahoo to motojon
Originally Posted by Joey4875 View Post
Did any of you guys have a problem making the caster clips fit with out have the arms bind up. I am having problems with both front and rear
I know for the rear we had to make the plastic plugs that go into the carbonfiber braces a little bigger. with them already installed we measured the pin witdh wich i think is 3mm and had to ream out the hole a little bigger. the hole colapse a little when their installed into the braces making it a tight fit as soon as you do that it should free up the rear end. As far as the front just use a pivot reamer to clean out the pin holes
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 05-03-2009, 05:15 AM   #527
morook's Avatar
Talking Keep the info coming Paolo..Thanks
Originally Posted by ck960 View Post
thanks for the info Paolo, Kendall
This new 966 is awesome..need to learn more to get the perfect setup. I'm learning and improving as i go...
morook is offline   Reply With Quote
Old 05-03-2009, 08:57 AM   #528
Originally Posted by Team Kamikaze View Post
Anybody that had a chance to drive the 966 will be sporting a big smile in their face.
+1
Mugen USA-FX Hobbies-Airtronics
TONY CLARK
STRICTLYSERPENT is offline   Reply With Quote
Old 05-03-2009, 04:18 PM   #529
Default help with car handling !!
was down a track racing today... the car was fine until in off the fast sweeping corner where i turn in and the car slowed to stop !!! If wider line taken it is ok, but tighter line the car sort of hooked to a stop....what can i do without upsetting too much changes ?
xtreme888 is offline   Reply With Quote
Old 05-04-2009, 02:56 AM   #530
Pattojnr's Avatar
Trader Rating: 19 (100%+)
so guys i got the upgrade kit heading to the place ill be staying at in SA.
so i will have one night to get things together, and am after any tips on installation that may be needed , as time will be short. and a setup maybe for a low to med traction track, bit open, but still alot of steering needed. thanks.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-04-2009, 04:26 AM   #531
Did you check the front CVD aren't binding?
Edgar Millenium is offline   Reply With Quote
Old 05-04-2009, 04:56 AM   #532
dj apolaro's Avatar
It sounds to me like you could also be locking the front wheel. Maybe too much through left and to right. Take out some travel and try that. Also make sure you have equal left to right travel when you do this.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-04-2009, 08:08 AM   #533
Pattojnr's Avatar
Originally Posted by Paolo M View Post
You don't need a different spring. You need to set the clutch like this:
Fly weigths: Pivoting and opening in the reverse rotation of the engine
Gap: 0.8
End Play: 0.3
Spring Pre-Load: 1.2 to 1.5
Engine is going to rev and have a violent clutch engagement . If you need more, put more load in the spring. If the track is dusty or no traction, you will need less pre-load
Hope this helps
Paolo, i have a 08 960, i have the 966 upgrade set , about to fit it in a week and a few days. this clutch setup, i have original throw out shoes on it in the kit of the 08. would a hole be suitable to make it open in reverse direction ? or would it lighten the shoe too much for this setup ? i dont have enough time to get the right shoes for this. would it work ok ? thanks. Patto....
Serpent - Walter RC
Old 05-04-2009, 08:16 AM   #534
the hole u are mentioning it's fine. Will work. Make sure you make the hole in the same position in each shoe
RCtarget, Capricorn, Novarossi, Maxima MX Fuel, Matrix, Xtreme Aero, Avid, Ko Propo, Veytrex Lab, Blast RC, PMR
Paolo M is offline   Reply With Quote
Old 05-05-2009, 03:55 PM   #535
hi...
stripped the car apart and found out that the the front cvd where the holder that pin go through had gone out of shape !!! Hence when full lock the drive shaft sort of notchy feeling at the same point very time...
Old 05-05-2009, 06:04 PM   #536
JFCJ's Avatar
Trader Rating: 31 (100%+)
We found that the setscrew in the cvd created a bind at times... since the bearing holds the pin in...we removed the setscrew.
* www.tsrcar.com * John's BSR Racing Tires * Serpent America * BOCA Bearings *
JFCJ is offline   Reply With Quote
Old 05-06-2009, 02:24 PM   #537
LOW ET's Avatar
Trader Rating: 96 (100%+)
what's the battery of choice for this car? nimh or lipo?
LOW ET is offline   Reply With Quote
Old 05-07-2009, 05:11 AM   #538
JFCJ's Avatar
Xceed lipo reciever pack (1300 Mah) with brass tray.
Old 05-07-2009, 10:19 PM   #539
Team Kamikaze's Avatar
Originally Posted by nitrodude View Post
The kamikaze Team will be at Crystal park this Sunday April 19 and will be on hand in helping racers with their new Serpent 966 car, other brands are welcome as well
We are doing it again this weekend! in preparation of the Kamikaze Invitational race on May 16 and 17, so anybody that needs help on their 966 should make them self available this Sunday.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-08-2009, 09:47 AM   #540
Green Machine!'s Avatar
Send a message via MSN to Green Machine!
Not to sound like I'm brown nosing or jumping on the Serpent band wagon, I have to say this: On a manufacturing , assemby, tuning, and rebuilding standpoint, this 966 is unbelieveable. Everything is so easy to get to and adjust it's not even funny. I haven't driven it yet and I am no means the greatest driver, but from what I've seen and touched, this car is the top of the line race car. The quality of the parts that come standard in the kit is unbelieveable as well. Sorry it took me so long to get talked into this kit. If everyone had the oppurtunity to get full hands on experience on all 1/8th cars before they had to shell out the money, I think everyone would be driving this car (asside from biassed sponsored and team drivers of other brands) Sorry, I just had to post my opinion.
Team Kamikaze
966 Garden Snake
obsessive compulsive (help me!)
Team Kamikaze.
XCEED RC
SERPENT
FUTABA
SSCLCG
Green Machine! is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
