Old 04-22-2009, 03:28 PM   #496
nitrodude's Avatar
As far as the FDR, I dont know. The offset is 7mm, I like to run 8mm too.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-22-2009, 04:00 PM   #497
GMartinez's Avatar
Trader Rating: 83 (100%+)
Originally Posted by captian View Post
ok i think we are trying to say the same thing somewhat . in paolo setup he used the big bearing in one part of his setup which centers the axle . and in the change he made eccentic was used with the small bearing which pushed the axle up . thats why it said its better if he had the setup book. but i hope it helps him with his serpent
+1 Cap I am not using the eccentrics & using the bigger bearings which puts in a neutral axle postion. for the steering blocks more steering is what I noticed
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup
2014 Hosted Events Roar Paved Electric Nationals, IFMAR ISTC Worlds
2015 Roar Fuel On Road Nationals,U.S.World Nitro Cup Completed
2016 U.S. World Nitro Cup Dec 7th - Dec 11th
GMartinez is offline   Reply With Quote
Old 04-22-2009, 04:05 PM   #498
nitrodude's Avatar
Regardless of Knuckle position, axle height can be preserved (Purpose of eccenters). In either a level or upper position to simulate a lower or "normal" front one-way (Roll Center).
The change of the knuckles changes both steering response and level of steering on throttle.
Download the PDF, I got it off the Serpent website.
Steven Muller
Ronin Speed Parts
Old 04-22-2009, 06:51 PM   #499
captian's Avatar
Originally Posted by nitrodude View Post
We're talking about 2 different things. The eccenters change axle height, you can run the axle low or high with the eccenters, or if you use the big bearing it will be centered with the oneway.
What Automator asked is not axle height. You can swap the knuckles left to right. One knuckle has a #2 and the other one has a #1, its not like it used to be when one had an R and the other a L. There is no left or right. Depending on which side you mount the #2(or #1 if you like) the height of the steering arm changes. If you moung the #2 on the left the steering arm (on the knuckle) is higher. They are called WOS knuckle and they used to be an option on the 960 07, now they come standard.
wow nitrodude i see you are taking it the wrong way . i thought what automator was asking about was paolo's setup that he posted right?? i hope he got what he needed from what you explaned thats all that counts.
note as for the wos knuckles they where first used on the vector nt and the veteq cars first and they where options back then if you knew how to make them work.
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 04-22-2009, 06:53 PM   #500
captian's Avatar
very well put nitrodude
Old 04-22-2009, 06:54 PM   #501
captian's Avatar
hi george hope to see you at the classic!!!!
Old 04-22-2009, 07:34 PM   #502
GMartinez's Avatar
No Doubt it's just aroung the corner
Old 04-22-2009, 11:07 PM   #503
I was more or less trying to figure out how to gear the car, since the Serpent has a bigger rear axle pulley than the Mugen and I believe the Kyosho, not sure about the Kyosho. Also the Serpent uses one tooth less on the front side pulley, a 25 compared to the 26 used on the Mugen and Kyosho. Just wondering how those different pulleys on the Serpent are going to affect gearing on 1st and 2nd gear.
automator is offline   Reply With Quote
Old 04-22-2009, 11:11 PM   #504
Yeah I was originally asking what difference the #1 and #2 steering blocks made as I didn't even notice that the arm would change heights when swapped. But the information on the eccentrics is definitely good stuff as that will help as well.
Thanks to both of you. All good information.
Old 04-24-2009, 07:51 AM   #505
captian's Avatar
it all has too do with what engine you are useing and its power range and the size of the track and tire size for roll out. but stock is good to start.
Old 04-25-2009, 06:14 AM   #506
Josue24's Avatar
Hey guys: I just saw that there is 1 966 on stock in serpent america web site.
Josue "josh" Valentine
Serpent America
Josue24 is offline   Reply With Quote
Old 04-25-2009, 11:23 AM   #507
LOW ET's Avatar
Trader Rating: 94 (100%+)
kamikaze has 4 in stock. great place to deal with. i got my 720 '08 from them and now a 966. it should be here any day
http://www.kamikazercracing.com/products.php?cat=68
LOW ET is offline   Reply With Quote
Old 04-25-2009, 11:56 AM   #508
Team Kamikaze's Avatar
You said it, yours will be on it's way.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-26-2009, 09:04 AM   #509
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Congrats to Mark Green and his 966 for the TQ and win at EFRA GP. watched the whole race, was very interesting strategies for tire stops. Salven had an issue with his car, not sure what it was, but it got back out and was fast.
might have to look at getting the upgrade fro my 08 now, since it seems to chenge the car so much
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-26-2009, 06:18 PM   #510
Trader Rating: 40 (100%+)
+1 on the Congrats to Mark Green . The Rear of his 966 looks to have more Alu-parts. in the center under the swaybar.
Got the grip is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
