Old 04-17-2009, 01:21 AM   #466
M7H
M7H's Avatar
Originally Posted by amuse View Post
it can still be done, but you will need to upgrade at least the rear of the car to 08 spec, then but the 966 conversion kit.
i am actually in the process of upgrading my original 960 to not-so-full 08 spec and most likely sometime in the mid season i'll convert it to the 966 spec.
upgrading to the 08 spec, you have a choice of either OS1 or OS2. OS1 uses Serpent wheels, and OS2 uses Mugen/Kyosho wheels.
from what i've read so far, the chassis is not necessary to get the 08 spec, when it's time for me to do the 966 conversion, the 966 chassis is part of the conversion kit.
hopefully my explaination is clear, if you need a list of parts for converting your original 960 to the 08 spec, let me know and i can list them out for you.
And don't forget to upgrade to the V2 break system!
http://www.serpent.com/product/903280/
Or actually you need:
http://www.serpent.com/product/903282/
and
http://www.serpent.com/product/903281/
Because in the kit a new retainer is supplied, based on the V2 brake system.
(new3 already mentioned this in his post)
Serpent 966
Serpent
M7H is offline   Reply With Quote
Old 04-17-2009, 08:38 AM   #467
hello- hur dum ar du ? paano bopol ka ? wie dumm sind sie ?
SERPENT AMERICA / Desoto Racing / kosmic fuel
michael 1 is offline   Reply With Quote
Old 04-17-2009, 08:11 PM   #468
Default 966 std flywheel size
Hi guys, i just got my 966 kit last few week and when i assemble the clutch it came with a 38mm flywheel. It should be a 36mm flywheel right due to the LCG engine mount being used... What the size of the flywheel u guys getting in the new kit?? thanks...
one more thing, i used to setup my clutch with brown shoe with 0.7/0.8 gap and tension starting form 1.2mm and with screws in the weight.
What gap and tension u guys run with the red shoe?? the new clutch went to dust with the stock setup?? wonder why?? any possibility the new clutch was warp??
i put in my old clutch set from my 08 everything went fine.
thanks
ck960 is offline   Reply With Quote
Old 04-17-2009, 11:49 PM   #469
Send a message via Yahoo to motojon
Spent all day at the Kamikaze shop. Nigel spent all day going through my 966 setting up my car, giving me the ends and outs of the car and what to expect. Thanks as always Sam and Nigel
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 04-18-2009, 03:34 AM   #470
M7H
M7H's Avatar
The 960'08 kit also had a LCG chassis and engine mount, and also came with a 38mm flywheel, I upgrade to the 966, so don't know what flywheel needs to be in the kit, but I can assure you that the 38mm will work perfectly.
Serpent
Old 04-18-2009, 07:24 AM   #471
i have a 960 08 also i think around the first batch it came with a 36mm.. at serpent site also noted i came with a smaller flywheel for LCG??
ok maybe i'll just try it out...
any suggestion running the red shoe clutch setting?? anyone.. thanks
Old 04-18-2009, 10:51 PM   #472
nitrodude's Avatar
The kamikaze Team will be at Crystal park this Sunday April 19 and will be on hand in helping racers with their new Serpent 966 car, other brands are welcome as well
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-19-2009, 07:40 PM   #473
SlowPushin's Avatar
whats the advantage of the zytec body over the central
IT's Not THe CAR,IT's THe NUT on the GRIP
S e r p e n t [7 4 7] [4 1 1]
SWEEP TIRES
ENNETI TIRES
SlowPushin is offline   Reply With Quote
Old 04-19-2009, 09:56 PM   #474
nitrodude's Avatar
The Zytec has more steering yet its stable in the back. The body is just a lot more stable. You really have to drive one to see the difference, it cant be descrived. The first time I tried the Zytec I went "Oh my god!!!", its that good.
Steven Muller
Ronin Speed Parts
Old 04-19-2009, 10:44 PM   #475
Team Kamikaze's Avatar
The major advantage of the Zytec body over Central Lola is the availability, ZYTEC is available while the Central Lola is not (have been discontinued in the US)
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-20-2009, 09:01 AM   #476
It solves a lot of set-up concerns. I had a midhigh speed push that would never go away with whatever set-up i tried. Put the Zytec on and it fixed that problem it was night and day better than R12, R11, Blitz
My Gpa(RIP)
Old 04-20-2009, 10:10 AM   #477
Trader Rating: 32 (100%+)
Has any one run the Zytec and compared it to the 909?
Monti
Monti is offline   Reply With Quote
Old 04-20-2009, 10:16 AM   #478
1fastdude's Avatar
Trader Rating: 15 (100%+)
Not yet............................................... ...
Team Horizon-Team Spektrum-Tekno-Kyosho*B-FAST R/C Performance*TQ Racing Wire Products-TNT-FX.COM-Avid RC-Dynamite-*AKA*92Zero Design*
1fastdude is offline   Reply With Quote
Old 04-20-2009, 10:39 AM   #479
Monti
Yes, the Serpent team have tried the ZYTEC on their 966 and some experience a slight push on the other body, the ZYTEC is more agile but still stable if compared to the other body, some like the ZYTEC, some don't, I guess it depends on the driving style.
Old 04-20-2009, 02:05 PM   #480
JFCJ's Avatar
Trader Rating: 31 (100%+)
Monti,
Clay has one... but hasn't run it yet... I may order one to try it out...
J
* www.tsrcar.com * John's BSR Racing Tires * Serpent America * BOCA Bearings *
JFCJ is offline   Reply With Quote
Serpent 960.... M7H Nitro On-Road 3281 11-14-2013 10:23 AM
Team Kamikaze Rc Racing Team Kamikaze Racing Forum 17924 08-31-2012 03:25 PM
Serpent's Lair ordinaryzam Malaysian R/C Racers 316 10-30-2009 12:29 AM
1/8th & 1/10th 200mm GAS POWERED ON ROAD OPEN RACE Kylelim Singapore R/C Racers 98 04-24-2009 11:10 PM
Melaka Club Race 1/8, 1/10 GP and EP 2WD MINI - 1st March 09 zali_sh Malaysian R/C Racers 185 03-09-2009 10:36 PM
